您的位置:控制工程论坛网论坛 » 工业以太网 » 泓格具有PoE,Modbus可编程设备服务器,RS-232*1,Rs-485*4的PPDSM-755-MTCP
szsxry
szsxry   |   当前状态:在线
总积分:405  2025年可用积分:0
最后登录时间: 2021-12-24
szsxry  发表于 2018/11/27 15:48:43      644 查看 0 回复  [上一主题]  [下一主题]
产品介绍:具有PoE,Modbus可编程设备服务器,RS-232*1,Rs-485*4
产品特点:
  • Incorporate Serial Devices in an Ethernet network
  • "Virtual COM" Extend COM Ports
  • Virtual COM on Windows NT 4.0, 2000/XP/2003 and Vista32
  • Powerful Programmable Device Server
  • Watchdog Timer suitable for use in harsh environments
  • Power Reverse Polarity Protection
  • Serial Port +/-4 kV ESD Protection Circuit
  • Self-Tuner ASIC Controller on the RS-485 Port
  • 5-digit LED Display (for versions with a display)
  • RoHS Compliant with no Halogen
  • Built-in High Performance MiniOS7 from ICP DAS
  • 10/100 Base-TX Ethernet, RJ-45 Port
    (Auto-negotiating, auto MDI/MDI-X, LED indicator)
  • ODM Service Is Available
  • Low power consumption
  • Palm-Sized with multiple Serial Ports
  • Made from fire retardant materials (UL94-V0 Level)
    [PPDS(M)-755(D)-MTCP only]
  • Supports Modbus TCP to RTU/ASCII Gateway
  • Supports PoE (IEEE 802.3af, Class 1)
产品规格:
Models
PDS(M)-755(D)
PPDS(M)-755(D)-MTCP
CPU
CPU
80186-80 MHz or compatible
SRAM
512 KB
Flash Memory
Flash ROM: 512 KB ; Erase unit is one sector (64 KB) ; 100,000 erase/write cycles
EEPROM
16 KB; Data retention: 40 years; 1,000,000 erase/write cycles.
Built-in Watchdog Timer
Yes
Communication Interface
Non-isolated
COM1
RS-232 (TxD, RxD, RTS, CTS, GND)
COM2
RS-485 (D2+, D2-, GND)
COM3
RS-485 (DATA+, DATA-, GND)
COM4
COM5
Ethernet
10/100 Base-TX, RJ-45 port (Auto-negotiating, auto MDI/MDI-X, LED indicator)
PoE
IEEE 802.3af
COM Port Formats
Data Bit
7, 8: for COM1 and COM2 5, 6, 7, 8: for COM3 ~ COM5
Parity
None, Even, Odd, Mark, Space
Stop Bit
1, 2: for COM1 ~ COM5
Baud Rate
115200 bps Max.
LED Indicators
5-digit 7 Segment
Yes, only for "D" versions
System
Red
PoE
Green
Power
Protection
Required Supply Voltage
+10 VDC ~ +30 VDC(non-regulated)
PoE or +12 VDC ~ +48 VDC(non-regulated)
Power Consumption
PDS(M)-755: 2.0 W PDS(M)-755D: 2.7 W
PPDS(M)-755-MTCP: 2.2 W PPDS(M)-755D-MTCP: 2.9 W
Mechanism
Flammability
Fire Retardant Materials (UL94-V0 Level)
Dimension (W x H x D)
72 mm x 123 mm x 35 mm (88 mm x 123 mm x 28 mm for "M" versions)
Installation
DIN-Rail or Wall mounting
Casing
Fire Retardant Plastic (Metal for "M" versions)
Environment
Operating Temperature
-25 ~ +75 °C
Storage Temperature
-40 ~ +80 °C
Humidity
5 ~ 90% RH, non-condensing
