产品介绍: 微型PoE端口设备服务器,RS-232*1
产品特点:
Incorporates any RS-232/422/485 serial device in Ethernet
Includes a VxComm Driver for 32-bit and 64-bit Windows XP/2003/2008/Vista/7
Supports pair-connection (serial-bridge, serial-tunnel) applications
Contains a 32-bit MCU that efficiently handles network traffic
10/100 Base-TX Ethernet, RJ-45 x 1 (Auto-negotiating, auto MDI/MDIX, LED Indicators)
Includes redundant power inputs: PoE (IEEE 802.3af, Class 1) and DC jack
Allows automatic RS-485 direction control
Supports TCP, UDP, HTTP, DHCP, BOOTP and TFTP protocols
Supports UDP responder for device discovery
Allows easy firmware update via the Ethernet
Contains a tiny Web server for configuration
Male DB-9 or terminal block connector for easy wiring
Tiny form-factor and low power consumption
RoHS compliant with no Halogen
Made from fire retardant materials (UL94-V0 Level)
Cost-effective device servers
产品规格:
System | |
CPU | 32-bit ARM |
Communication Interface | |
Ethernet | 10/100 Base-TX, 8-pin RJ-45 x 1, (Auto-negotiating, Auto-MDI/MDIX, LED indicator) PoE (IEEE 802.3af, Class 1) |
COM1 | 5-wire RS-232 |
UART | 16c550 or compatible |
COM Port Format | |
Baud Rate | 115200 bps Max. |
Data Bit | 5, 6, 7, 8 |
Parity | None, Odd, Even, Mark, Space |
Stop Bit | 1, 2 |
Power | |
Power Input | PoE: IEEE 802.3af, Class 1 DC jack: +12 ~ 48 VDC |
Power Consumption | 0.05 A @ 24 VDC |
Mechanism | |
Connector | Male DB-9 x1 |
Mounting | DIN-Rail |
Flammability | Fire Retardant Materials (UL94-V0 Level) |
Environment | |
Operating Temperature | -25 ~ +75 °C |
Storage Temperature | -30 ~ +80 °C |
Humidity | 10 ~ 90% RH, non-condensing |
