您的位置:控制工程论坛网论坛 » 工业以太网 » 泓格微型PoE端口设备服务器tDS-722
szsxry
szsxry   |   当前状态:在线
总积分:405  2025年可用积分:0
最后登录时间: 2021-12-24
szsxry  发表于 2018/11/28 15:10:43      823 查看 0 回复  [上一主题]  [下一主题]
产品介绍:微型PoE端口设备服务器,RS-232*2
产品特点:
  • Incorporates any RS-232/422/485 serial device in Ethernet
  • Includes a VxComm Driver for 32-bit and 64-bit Windows XP/2003/2008/Vista/7
  • Supports pair-connection (serial-bridge, serial-tunnel) applications
  • Contains a 32-bit MCU that efficiently handles network traffic
  • 10/100 Base-TX Ethernet, RJ-45 x 1 (Auto-negotiating, auto MDI/MDIX, LED Indicators)
  • Includes redundant power inputs: PoE (IEEE 802.3af, Class 1) and DC jack
  • Allows automatic RS-485 direction control
  • Supports TCP, UDP, HTTP, DHCP, BOOTP and TFTP protocols
  • Supports UDP responder for device discovery
  • Allows easy firmware update via the Ethernet
  • Contains a tiny Web server for configuration
  • Male DB-9 or terminal block connector for easy wiring
  • Tiny form-factor and low power consumption
  • RoHS compliant with no Halogen
  • Made from fire retardant materials (UL94-V0 Level)
  • Cost-effective device servers
