您的位置:控制工程论坛网论坛 » 工业以太网 » 泓格微型Modbus/TCP打到RTU/ASCII网关,支持PoE,1个RS-422/485tGW-715
szsxry
szsxry   |   当前状态:在线
总积分:405  2025年可用积分:0
最后登录时间: 2021-12-24
szsxry  发表于 2018/11/28 15:23:04      535 查看 0 回复  [上一主题]  [下一主题]
产品介绍:微型Modbus/TCP打到RTU/ASCII网关,支持PoE,1个RS-422/485
产品特点:
  • Cost-effective Modbus/TCP to RTU/ASCII Gateway
  • Supports Modbus/TCP master and slave
  • Supports Modbus RTU/ASCII master and slave
  • Contains a 32-bit MCU that efficiently handles network traffic
  • 10/100 Base-TX Ethernet, RJ-45 x 1 (Auto-negotiating, auto MDI/MDIX, LED Indicators)
  • Includes redundant power inputs: PoE (IEEE 802.3af, Class 1) and DC jack
  • Allows automatic RS-485 direction control
  • Supports TCP, UDP, HTTP, DHCP, BOOTP and TFTP protocols
  • Supports UDP responder for device discovery
  • Allows easy firmware update via the Ethernet
  • Contains a tiny Web server for configuration
  • Male DB-9 or terminal block connector for easy wiring
  • Tiny form-factor and low power consumption
  • RoHS compliant with no Halogen
  • Made from fire retardant materials (UL94-V0 Level)
产品规格:
System
CPU
32-bit ARM
Communication Interface
Ethernet
10/100 Base-TX, 8-pin RJ-45 x 1, (Auto-negotiating, Auto-MDI/MDIX, LED indicator) PoE (IEEE 802.3af, Class 1)
COM1 (TCP Port: 502)
2-wireRS-485 4-wire RS-422
COM2 (TCP Port: 503)
COM3 (TCP Port: 504)
Self-Tuner
Yes, automatic RS-485 direction control
UART
16c550 or compatible
COM Port Format
Baud Rate
115200 bps Max.
Data Bit
5, 6, 7, 8
Parity
None, Odd, Even, Mark, Space
Stop Bit
1, 2
Power
Power Input
PoE: IEEE 802.3af, Class 1 DC jack: +12 ~ 48 VDC
Power Consumption
0.05 A @ 24 VDC
Mechanism
Connector
10-Pin Removable Terminal Block x 1
Mounting
DIN-Rail
Flammability
Fire Retardant Materials (UL94-V0 Level)
Environment
Operating Temperature
-25 ~ +75 °C
Storage Temperature
-30 ~ +80 °C
Humidity
10 ~ 90% RH, non-condensing
