您的位置:控制工程论坛网论坛 » 过程控制系统 » 压力变送器
bjhsa
bjhsa   |   当前状态:在线
总积分:179  2025年可用积分:0
最后登录时间: 2020-08-04
压力变送器
bjhsa  发表于 2019/5/9 11:13:06      1799 查看 1 回复  [上一主题]  [下一主题]
PB-DA-2Y(A.B.C.D)系列压力变送器
PB-DA-2Y(A.B.C.D) Series Pressure Transmitters
  1. 用途
    I Functions
    PB-DA-2Y列产品利用专利技术与德国Analog Microectcsco.,Ltd公司合作开发的新型压力变送器,采用精密光刻箔式电阻应变计及德国AMG公司生产的专用变送器用集成电路。它设计新颖独特,工艺先进,信号输出稳定,优良的性能价格比,是远传压力表的理想替代产品。它可广泛应用于冶金、电力、自来水、化工和石油等工业现场,实现远程监控和控制。
    With the patented technology and developed in cooperation with German Analog Microectcsco., Ltd, PB-DA-2Y Series products as new pressure transmitters adopt precision lithography foil resistance strain gauge, and dedicated transmitter-use integrated circuits from AMG. They are featured with unique design, advanced manufacturing technology, stable output signals and cost-effective figures. It is a kind of ideal alternative for transmissible pressure gauge and can be widely used in metallurgy, electronics, tap-water, chemical and oil industries, which can realize remote monitoring and network control.
  2. 技术参数
    II Technical Parameters
  3. 信号输出精度:1.0 级
    The accuracy of signal outputs: 1.0 degree
  4. 表面指示精度:1.6 级
    2. The accuracy of surface indicator: 16 degree
    3.量程:-0.1—0.3Mpa 0~0.4Mpa 00.6Mpa  01.0Mpa
    01.6Mpa 02.5Mpa 04.0Mpa  06.0Mpa
         3. Measuring Range:
     4.信号输出:4-20mA / 0-20mA / 0-10mA / 0-5V/1-5V
         4. Signal Outputs:
    5.工作电压:24V DC    负载电阻:1.2KΩ(标准24V/DC电源)
    5. Operating Voltage:24V DC  Load Resistance: 1.2KΩ(Standard 24V/DC Power Outlet)
    6.传输方式:二线制数字化智能       三线制
    6. Transmission Mode: two-wire digital intelligence   three-wire system
    7.接头螺纹:ZG1/2       M20x1.5
    7. Connection Thread
    8.使用温度:-20~45℃
    宝鸡华水自动化工程有限责任公司    WWW.HSA.CN
    电话:0917-2811180 /3802128 /3802129 传真0917-2811180
    13991722188   15353016717  微信同号
