您的位置:控制工程论坛网论坛 » 嵌入式系统 » [FPGA/CPLD]8位数据锁存器
mcumao
mcumao   |   当前状态:离线
总积分:1503  2025年可用积分:0
最后登录时间: 2007-06-11
[FPGA/CPLD]8位数据锁存器
mcumao  发表于 2006/4/4 14:11:02      1371 查看 0 回复  [上一主题]  [下一主题]
-- DESCRIPTION   :  Flip-flop D type
--                  Width: 8
--                  Clock active: high
--                  Synchronous clear active: high
--                  Synchronous set active: high
--                  Clock enable active: high
--                  Load active: high
library IEEE;
use IEEE.std_logic_1164.all;
entity ffd is
port (
CLR : in std_logic;
SET : in std_logic;
CE : in std_logic;
LOAD : in std_logic;
CLK : in std_logic;
DATA_IN : in std_logic_vector (7 downto 0);
DATA_OUT : out std_logic_vector (7 downto 0)
end entity;
architecture ffd_arch of ffd is
signal TEMP_DATA_OUT: std_logic_vector (7 downto 0);
begin
process (CLK)
begin
if rising_edge(CLK) then
if CE = '1' then
if CLR = '1' then
TEMP_DATA_OUT <= (others => '0');
elsif SET = '1' then
TEMP_DATA_OUT <= (others => '1');
elsif LOAD = '1' then
TEMP_DATA_OUT <= DATA_IN;
end if;
end if;
end if;
end process;
DATA_OUT <= TEMP_DATA_OUT;
end architecture;
