您的位置:控制工程论坛网论坛 » 产品供求 » SCLP 2.4G DSSS Radio Modem Series
dtinfo
dtinfo   |   当前状态:离线
总积分:255  2025年可用积分:0
最后登录时间: 2008-03-15
dtinfo  发表于 2007/11/2 1:55:22      1036 查看 0 回复  [上一主题]  [下一主题]
Dependable and Reliable for Different Applications, Compact size and Very low Power
  Long Range
  250m – 8000 m (LOS)
  High Data Rate
  250Kbps DSSS, 1Mbps GFSK
  Interface
  UART, RS232 & RS485
  Manufacturer ID
  6 bytes
  Working Temperature
  –40° to 85°C
  Adjustable Parameters
  Power output & Receiving sensitivity
  (Either via RS232 or in Air)
  Data rate & Module ID
  Frequency band & PN code
Note:
1. All Modems are made from Cypress LP Transceiver IC and having same
basic specifications as LP transceiver.
2. Communication range depends on:  gain of antenna, height of antenna,
transmitting power and receiving sensitivity, also the environment of the path.
Following are main modules available:
Module A:  Max Range: A A 250m
(PCB antenna set at 3m above ground)
Current: 18 mA – 35mA
@ 2.7 --- 3.6 V DC
Max output:  4 dBm
Dimension: 30 x 27 x 3 mm or Smaller
Module B:  Max Range: BB  8000m
(high Gain and high mounted antenna)
BB  3000m
(10 cm antenna mounted 3m high)
Current: 35 mA – 330mA
@ 2.7 --- 5 V DC / 110V / 220V AC
Max output:  20 dBm
Dimension: 48 x 24 x 10 mm (RF part)
Module b:  Max Range: bb  1000m
(PCB antenna mounted 3m high)
Current: 25 mA – 200mA
@ 2.7 --- 5 V DC
Max output:  20 dBm
Dimension: 42 x 25 x 3.6 mm
Mixing Module Range:  AB   600m
(A with PCB antenna, B with 10 cm small antenna and both
mounted 3m high)
BA  1600m
(b with PCB antenna, B with 10 cm small antenna and both mounted 3m high)
bB  2000m
Bb  1400m
We also serve our clients as a design house, and provide following turn key solutions: Long range active RFID, Car and assets tracing & positioning system, Auto metering system,…… For more Information, please call +86-21-64365830, or send email to shsc@yahoo.cn.
