您的位置:控制工程论坛网论坛 » 电机与运动控制 » 在win2k下使用ByteBlaster对CPLD编程的驱动程序安装
jiewinds
jiewinds   |   当前状态:离线
总积分:200  2026年可用积分:0
最后登录时间: 2007-01-25
jiewinds  发表于 2004/12/4 23:15:49      4364 查看 0 回复  [上一主题]  [下一主题]
在Altera站点上找的,不知是不是told,与大家共享: Q:Do I have to install a driver to use the ByteBlasterMV?, the Master Programming Unit (MPU) or the MasterBlaster? communications cable on the Windows 2000 operating system? Solution : Yes, you must install a driver to use the ByteBlasterMV or the Master Programming Unit (MPU) with the Windows 2000 operating system.You can install the driver by performing the steps below: 1.Open the Control Panel (Start menu -> Settings -> Control Panel). 2.Double-click on the Add/Remove Hardware icon to start the Add/Remove Hardware Wizard and click Next to continue. 3.In the Choose a Hardware Task panel, select the Add/Troubleshoot a device radio button and click Next to continue. Windows 2000 will search for new Plug-and-Play hardware (in the New Hardware Detection window). 4.In the Choose a Hardware Device window, select Add a new device and click Next to continue. 5.In the Find New Hardware window, select the No, I want to select the hardware from a list radio button and click Next to continue. 6.In the Hardware Type window, select Sound, video and game controllers and click Next to continue. 7.In the Select a Device Driver window, select Have Disk .... 8.Specify the full directory path to the win2000.inf file (e.g., \drivers\win2000) and click OK. 9.In the Digital Signature Not Found warning dialog box, click Yes to continue the installation. 10.In the Select a Device Driver window, select Altera ByteBlaster for the ByteblasterMV or select Altera Programmer for the Master Programming Unit (MPU). Then click Next to continue. 11.The Start Hardware Installation window displays the hardware being installed. Click Next to continue. 12.In the Digital Signature Not Found warning dialog box, click Yes to continue the installation. 13.In the Completing the Add/Remove Hardware Wizard window, click Finish to continue. 14.A system dialog appears prompting a reboot so that the new settings can take effect. Windows 2000 should auto-detect the MasterBlaster download cable when it is plugged into the USB port.
