您的位置:控制工程论坛网论坛 » 产品供求 » macnaught/macnaught手动油脂泵/macnaught手动油脂泵K6K3系列
jmmy8888
jmmy8888   |   当前状态:离线
总积分:227  2025年可用积分:0
最后登录时间: 2011-12-08
jmmy8888  发表于 2007/11/29 14:16:52      825 查看 0 回复  [上一主题]  [下一主题]
点击图片放大
macnaught手动油脂泵
macnaught手动油脂泵
名称︰macnaught手动油脂泵
型号︰K6系列
品牌︰macnaught
原产地︰澳大利亚
产品描述
K6 Mini-lube®
designed to fit pails from 2.5kg (5lb) to 5kg (11lb), or with depths of 146mm to 225mm
includes pump unit, lid, rubber edged follower, 1.5m (5 ft) x 1/2" ID delivery hose, and the high pressure, high volume KR grease gun
(all components also available separately)
K6-24 contains the above items plus a 2.5kg (5lb) refillable container (KT5), while the K6-67 contains the above items plus a 5kg (11lb) refillable container (KT6)
spring loaded pump system provides 30 shots of grease
suitable for greases up to and including NLGI no.2
360° swivel to prevent hose kinking
fully sealed to prevent contamination
5 year warranty (conditions apply)
10 year parts availability
点击图片放大
macnaught手动油脂泵
macnaught手动油脂泵
名称︰macnaught手动油脂泵
型号︰K3系列
品牌︰macnaught 玛乐
原产地︰澳大利亚
产品描述
bilitydesigned to fit pails from 12.5kg (28lb) up to 22kg (48lb), or with depths of 310mm to 430mm
supplied with the pump unit, lid, rubber edged follower, 3m (10 ft) x 1/2" ID delivery hose, and the high pressure, high volume KR grease gun (all components also available separately)
spring loaded pump system provides 60 shots of grease
suitable for greases up to and including NLGI No.2
optional TR5 drum trolley to provide portability
产品图片
macnaught手动油脂泵
相关产品
macnaught手动油脂泵
macnaught手动油脂泵
气动黄油机
气动黄油机
气动机油机
气动机油机
macnaught自动回卷器
macnaught自动回卷器
