caizhengsuo | 当前状态:在线
总积分:3196 2025年可用积分:0
最后登录时间: 2015-10-16
各种液压阀门中英文对照
caizhengsuo 发表于 2008/4/2 9:08:20 1272 查看 0 回复 [上一主题] [下一主题]
Globe valve ——截止阀
Gate valve ——闸阀
Ball valve ——球阀
Pneumatic flanged ball valve ——气动法兰球阀
Wafer check valve ——对夹式止回阀
Electric control valve ——电动调节阀
Pressure reducing valve ——压力减小阀
Remote-controlled float valve ——遥控浮球阀
Double-flange compensatory couplings ——双法兰限位伸缩器
Hydraulic control valve ——液压水位控制阀
Soft seal gate vale ——软密封闸阀
Microresistance slow closing check valve ——微阻缓闭止回阀
Worm wafer butterfly valve ——涡轮对夹式蝶阀
Flanged telescopic butterfly valve ——法兰伸缩式蝶阀
Eletric flange telescopic butterfly valve ——电动法兰伸缩式蝶阀
Pipenet eccentric butterfly valve ——管网式偏心蝶阀
Electric double-flange eccentric butterfly valve ——点动双法兰偏心蝶阀
Hand lever nylon coated etch-proof butterfly valve ——手柄式尼龙覆层防腐蝶阀
Hand lever LT butterfly valve ——手柄式单式蝶阀
Signal butterfly valve for fire fighting ——消防信号蝶阀
Metallic seal wafer butterfly valve ——硬密封对夹式蝶阀
