您的位置:控制工程论坛网论坛 » 传感器 » 供应霍尔元件 A3955 资料下载
szyhxing
szyhxing   |   当前状态:离线
总积分:148  2025年可用积分:0
最后登录时间: 2008-07-29
供应霍尔元件 A3955 资料下载
szyhxing  发表于 2008/4/15 16:17:21      926 查看 0 回复  [上一主题]  [下一主题]
型号:A3955SB-T
品牌:ALLEGRO
封装:16-pin DIP
包装:15PCS/管
产地:美国
特征、应用:最大1.5A的最大驱动电流,最高50V的供电电压,带有过热自动关断保护电路,欠电压锁定(UVLO)保护,输出抗浪涌的瞬间保护功能,自带PWM 电流控制,3位的线性DAC,带细分控制,不同组合不同的细分数,最多8细分
主要就用于:打印机、刻字 /雕刻机、生化分析仪、扫描仪 传真机 绘图仪 机器人 等
技术资料:
FULL-BRIDGE PWM
MICROSTEPPING MOTOR DRIVER
The A3955SB and A3955SLB are designed for driving one winding
of a bipolar stepper motor in a microstepping mode. The outputs are
rated for continuous output currents to ±1.5 A and operating voltages
to 50 V. Internal pulse-width modulated (PWM) current control combined
with an internal three-bit nonlinear digital-to-analog converter
allows the motor current to be controlled in full-, half-, quarter-, or
eighth-step (microstepping) modes. Nonlinear increments minimize
the number of control lines necessary for microstepping.
Microstepping provides for increased step resolution, and reduces
torque variations and resonance problems at low speed.
Internal circuitry determines whether the PWM current-control
circuitry operates in a slow (recirculating) current-decay mode, fast
(regenerative) current-decay mode, or in a mixed current-decay mode
in which the off time is divided into a period of fast current decay with
the remainder of the fixed off time spent in slow current decay. The
combination of user-selectable current-sensing resistor and reference
voltage, digitally selected output current ratio; and slow, fast, or mixed
current-decay modes provides users with a broad, variable range of
motor control.
Internal circuit protection includes thermal shutdown with hysteresis,
transient-suppression diodes, and crossover current protection.
Special power-up sequencing is not required.
The A3955S— is supplied in a choice of two power packages; a
16-pin dual-in-line plastic package with copper heat-sink tabs (suffix
‘B’), and a 16-lead plastic SOIC with copper heat-sink tabs (suffix ‘LB’).
For both package styles, the power tab is at ground potential and
needs no electrical isolation.
FEATURES
n ±1.5 A Continuous Output Current
n 50 V Output Voltage Rating
n Internal PWM Current Control
n 3-Bit Non-Linear DAC
n Fast, Mixed Fast/Slow, and Slow Current-Decay Modes
n Internal Transient-Suppression Diodes
n Internal Thermal-Shutdown Circuitry
n Crossover-Current and UVLO Protection
联系人:陈文霞(小姐)
销售专线电话:0755-61636230,13682388017
MSN:szyhxing001@hotmail.com
QQ:604561153
贸易通:szyhxing
http://www.szyhxing.com
