DMT64480S_03W
5.7”, 640×480 dots, M600 Core, 65K colors TFT HMI
技术规格/Technical Specification
规格/Item 参数/Parameter
工作电压/Voltage DC4.5-28V
工作电流/Current 背光亮/Back Light ON 背光灭/Back Light OFF
(Voltage=12V) 210mA(亮度/Luminance 220cd/m2) 110mA
PIN# I/O 定义/description
1
2
In 供电电源输入/ Power supply in
3 Out 串口缓冲区满信号指示/RS232 DTR
4 Out 串口输出/RS232 TXD
5
6
In 串口输入/RS232 RXD
7
用户接口/Application Interface
(采用8 Pin 2.54mm 间距插座,相同定义的
管脚在内部已经连接到一起。/Apply an 8 Pin
2.54 mm connector, the same description
pin connected in PCB.)
8
Passive 地/GND
串口模式/Serial port mode 8,n,1 (8 data bit,1 stop bit, no check bit); 1200-115200bps adjustable.
面板类别/TFT panel type 中华映管(CPT) CLAA057VA01
有效显示区域尺寸/Active area dimension 116.16(L)×87.12(W) mm
外形尺寸/Outline dimension 144(L)×109.5(W)×22(H) mm
工作温度/Operation temperature -30--+85℃(受屏温度范围限制/Limited by panel)
净重量/Net weight 230g (DMT64480S_03WN)
文本格式/Text style 8×8-128×128 点阵字体,32MB 字库,支持GB2312、GBK、BIG5、S-JIS
(日文)、HANGEL(韩文)、UNICODE 编码。
8×8-128×128 dots text, Build-in 32MB text library, support
GB2312,GBK,BIG5,S-JIS(Japanese),HANGEL(Korean),UNICODE text
encode standard.
图片存储空间/Picture memory 96MB (153 幅全屏图片/153 full screen pictures)
触摸屏支持/Touch screen support 4 线电阻触摸屏/4 wires resistor touch screen
指令集/Command sets M600 指令集/M600 command sets.
典型应用/Typical application 自动化现场
选型指南/Select guide DMT64480S_03WN (不带触摸屏/without touch screen)
DMT64480S_03WT (带触摸屏/with touch screen)
- 12 -
DMT64480S_03W
装配尺寸图/Mechanical Dimension
- 13 -
DMT64480S_04W
1
2
5
6
In 串口输入/RS232 RXD
7
8
Passive 地/GND
外形尺寸/Outline dimension 203(L)×159(W)×37(H) mm
安装开口尺寸/Mount hole dimension 193(L)×148(W) mm
净重量/Net weight 640g (DMT64480S_04WT)
encode standard.
典型应用/Typical application 便携式分析仪器、自动化现场
选型指南/Select guide DMT64480S_04WN (不带触摸屏/without touch screen)
DMT64480S_04WT (带触摸屏/with touch screen)
联系人: 杨云超 电话: 010-62102630-709 13466776941
邮件:yangyunchao1980@sina.com http://www.dwin.com.cn
babyamanda | 当前状态:离线
总积分:59 2025年可用积分:0
最后登录时间: 2008-05-08
babyamanda 发表于 2008/5/8 19:12:32
关注下..看看 关注下...
引用 babyamanda 2008/5/8 19:12:32 发表于2楼的内容
