您的位置:控制工程论坛网论坛 » 电机与运动控制 » wow gold:Mining Gold in World of Warcraft
brain01
brain01   |   当前状态:离线
总积分:60  2026年可用积分:0
最后登录时间: 2014-05-21
brain01  发表于 2008/5/8 10:37:50      1516 查看 2 回复  [上一主题]  [下一主题]
Gold is a wow goldshiny yellow metal, that for some reason everyone seems to wow goldwant. This is just as true in the real world, as it is in the virtual wow gold of online games. Games such as World of Warcraft. Here, while it is much less shiny then the real thing, it is much more useful as it is needed to buy pretty well everything. There are many ways to get WoW Gold, from killing things to finding it, but the easiest way is just to buy it.
When you kill a creature in World of Warcraft, it will usually drop an item or some gold for you to pick up. This is beside the usual experience points awarded for victory in combat. Experience is good as well, as it allows you to level up more quickly, and so become stronger and more easily able to defeat your next combat challenge or quest.
Of course, killing is not easy or fast, and so you really need to focus on it to gain a reasonable amount of gold. This may not be what you want, as it is a lot of effort, and so you also need to talk to the non-player characters scattered around the world. they will often give you quests, which which when completed will reward you with experience and sometimes gold as well.
  • 匿名
    匿名   |   当前状态:离线
    总积分:0  2026年可用积分:0
    匿名   发表于 2008/5/8 10:37:29
    wow goldworld of warcraft gold to our loyal  reliable customers.
    引用 匿名 2008/5/8 10:37:29 发表于2楼的内容
  • 匿名
    匿名   |   当前状态:离线
    总积分:0  2026年可用积分:0
    匿名   发表于 2008/5/8 10:37:50
    wow gold
    引用 匿名 2008/5/8 10:37:50 发表于3楼的内容
