qiyangkeji | 当前状态:在线
总积分:171 2025年可用积分:0
最后登录时间: 2021-03-17
PC/104半长卡
qiyangkeji 发表于 2008/5/23 13:24:20 923 查看 0 回复 [上一主题] [下一主题]
PC/104半长卡
产品简介:
QY-6124S主板采用半长卡设计,板载300MHz主频低功耗奔腾系列CPU,板贴128M系统内存,支持1280*1024分辨率TFT-LCD彩屏 。提供4个串口、4USB接口、网络接口
广泛适用于数据采集系统,工业自动化,过程控制,汽车控制器,智能车辆管理的设备 ,医疗设备,人机接口设备,机器人,机械控制等场合。
产品特点:
◆ 300 MHz Vortex86SX System-On-Chip
◆ VGA, TFT/LVDS LCD support up to
1280x1024 resolution
◆ 128MB DDR2 system memory
◆ Enhanced IDE (UltraDMA-100/66/33)
◆ 10/100Mbps Ethernet
◆ 4 USB 2.0 (host)
◆ Up to 4 serial ports
◆ Parallel port
◆ 16-bit GPIOs
◆ Onboard 2MB SPI Flash
◆ PC/104-Plus expansion bus
◆ Meet PC/104 stacking spec.
◆ 2 watchdog timer
◆ 3 PWM channels
◆ JTAG interface
◆ AMI BIOS
◆ Single voltage +5V DC
◆ Support extended operating
◆ temperature range of -20°C to +70°C
硬件配置:
芯片组 DM&P SoC CPU Vortex86SX- 300MHz
Real Time Clock with Lithium Battery Backup
Cache L1:16K I-Cache, 16K D-Cache
总线界面 PC/104 standard compliant
BIOS AMI BIOS
系统存储128MB DDR2 on board
看门狗r Software programmable from 30.5 to 512 seconds x
2 sets
( Watchdog 1 fully compatible with M6117D)
VGA(Optional) XGI Volari Z9s Chipset
VGA and TFT/LVDS Flat Panel Interface Support
Onboard 32MB VGA Memory, support resolution up to
1600x1200, 256 colors
网络 Intergraded 10/100M Ethernet
Flash Disk Support Onboard 2MB SPI Flash Disk (Optional)
MSTI EmbedDisk Module (16MB and above)
I/O口 Enhanced IDE port (UltraDMA-100/66/33) x1
RS-232 port x3
RS-232/422/485 port x1
USB port (2.0) x4
Parallel port x1
16-bit GPIO port x1
10/100Mbps Ethernet port x1
连接接口 2.54mm 40-pin box header for IDE x1
2.0mm 44-pin box header for LCD x1
2.54mm 26-pin box header for Printer x1
2.54mm 20-pin box header for 16-bit GPIO x1
2.54mm 10-pin box header for RS-232 x3
2.54mm 10-pin box header for USB x2
2.54mm 3-pin header for RS-485 x1
2.54mm 7-pin header for Redundancy Signal x1
2.54mm 2-pin header for System-Fail-SW x1
1.25mm 6-pin header for JTAG x1
External 15-pin D-Sub female connector for VGA x1
External 9-pin D-Sub male connector for RS-232 x1
External RJ-45 connector for Ethernet x1
External Mini DIN connector for Keyboard/Mouse x1
电源需求Single Voltage +5V @ 640mA
重量225g
尺寸 184 X 122mm (7.24 x 4.80 inches)
工作温度 -20°C ~ +70°C
定货信息:
VSX-6124 Vortex86SX Half-Size CPU Module with 128MB DDR2 Module
联系人:周先生
电 话:0571-87858822 87858811
传 真:0571-87858822
邮 箱:zjj@qiyangtech.com
地 址:杭州市山水人家诗家谷5幢1单元1楼
邮 编:310012
QQ:147420730
网址:http://www.qiyangtech.cn
