您的位置:控制工程论坛网论坛 » 工业以太网 » 世界上最小巧的串口转以太网模块NEPORT
conextop
conextop   |   当前状态:在线
总积分:195  2025年可用积分:0
最后登录时间: 2011-02-23
conextop  发表于 2008/9/16 12:04:38      1637 查看 8 回复  [上一主题]  [下一主题]
Features
> Easily network-enable multiple serial devices
> RS-232/485/422 provides an easy connection to any serial
device
> Neport series for COM or TTY port control and management
> Management and diagnostic utility for simple and efficient
device monitoring and troubleshooting
> Modem emulation allows existing modem-based applications
to make connections over IP networks
> Port buffering for data capture
> Easy configuration through web interface
> TELNET for easy remote management
> Tunable for low latency or optimized throughput
Multi-threads operation system and protocols Support
·  With multi-threads real time operation system embedded in a 32bits RISC
·  ARP, UDP, TCP, ICMP, Telnet, TFTP, AutoIP, DHCP, HTTP, for network communications.
·  TCP, UDP, and Telnet for connections to the serial port.
·  TFTP for firmware updates.(E version)
·  IP for addressing, routing, and data block handling over the network.
·  User Datagram Protocol (UDP) for typical datagram applications in which devices interact with other devices
without maintaining a point-to-point connection.
· SMTP: E-mail alerts
NePort series Evaluation Board
> Complete, ready to use module and supporting evaluation
board
> +9VDC Universal Power adaptor
> RS-232 cable, DB9 M/F
> CAT5e UTP RJ45M/M Ethernet cable
> Software CD-ROM containing a configuration utilityConextops
Installer and complete user manual in PDF
欢迎登录www.conextop.com.cn OR http://www.creativetop.com/cn
  • xsj19810419
    xsj19810419   |   当前状态:在线
    总积分:1642  2025年可用积分:0
    最后登录时间: 2024-06-26
    xsj19810419   发表于 2008/6/2 8:41:00
    引用 xsj19810419 2008/6/2 8:41:00 发表于2楼的内容
  • 匿名
    匿名   |   当前状态:离线
    总积分:0  2025年可用积分:0
    匿名   发表于 2008/7/3 9:27:53
    引用 匿名 2008/7/3 9:27:53 发表于3楼的内容
  • 匿名
    匿名   |   当前状态:离线
    总积分:0  2025年可用积分:0
    匿名   发表于 2008/7/4 9:03:56
    产品用在哪些方面?
    引用 匿名 2008/7/4 9:03:56 发表于4楼的内容
  • 匿名
    匿名   |   当前状态:离线
    总积分:0  2025年可用积分:0
    匿名   发表于 2008/7/5 10:42:05
    很多领域:门禁一卡通,考勤读卡器,楼宇设施,安防网络,设备自动化,PLC,cnc,电信部门,环境监测,检测仪表等
    引用 匿名 2008/7/5 10:42:05 发表于5楼的内容
  • bjmonsoon
    bjmonsoon   |   当前状态:在线
    总积分:1206  2025年可用积分:0
    最后登录时间: 2011-06-13
    bjmonsoon   发表于 2008/7/7 23:30:42
    TD-2000S是一款外挂式RS-485/422到TCP/IP的转换器(又称串口服务器,串口联网服务器,RS-485网卡,RS-485转网络,串口转网络)。是深圳市天地华杰科技有限公司为了解决RS-485/422串口设备快速联网而专业设计。TD-2000S串口服务器可采用三种工作模式:1. TCP服务器方式。2. TCP客户端方式。3. 自动方式。向上提供10M的网络连接,向下提供一个RS232串口,参数可通过浏览器设置。TD-2000S串口服务器支持点到点,点到多点的连接,支持广播或组播方式。TD-2000S串口服务器能将RS485/422信号双向透明地转换为网络信号,使用户在不用知道复杂的TCP/IP协议下,不用更改用户程序的条件下,即可实现串口设备与网络的联接,节省您宝贵的时间和已有投资
    6楼 回复本楼
    引用 bjmonsoon 2008/7/7 23:30:42 发表于6楼的内容
  • 匿名
    匿名   |   当前状态:离线
    总积分:0  2025年可用积分:0
    匿名   发表于 2008/7/14 10:41:47
    该产品支持以太网供电
    7楼 回复本楼
    引用 匿名 2008/7/14 10:41:47 发表于7楼的内容
  • conextop
    conextop   |   当前状态:在线
    总积分:195  2025年可用积分:0
    最后登录时间: 2011-02-23
    conextop   发表于 2008/8/16 16:46:50
    8楼 回复本楼
    引用 conextop 2008/8/16 16:46:50 发表于8楼的内容
