您的位置:控制工程论坛网论坛 » 电机与运动控制 » 有没有人会做这道题!!!!!!!!!!!!!!!
杨杨
杨杨   |   当前状态:离线
总积分:50  2025年可用积分:0
最后登录时间: 2008-06-19
杨杨  发表于 2008/6/19 10:43:08      719 查看 0 回复  [上一主题]  [下一主题]
Consider a discrete-time single input linear regulator problem where the control is designed via a linear quadratic cost function. Say that the input is required to satisfy a constraint of the form |u(k)| ≤ ∆. Use a receding horizon MPC
set-up for this problem. Hence show that if,in the solution to the optimization problem,on ly the first control is saturated then
u(k) = −sat(Kx(k)) (23.10.1) is the optimal constrained control where u(k) = −Kx(k) is the optimal unconstrained
control (Hint: use Dynamic Programming and examine the last step of the argument).
