您的位置:控制工程论坛网论坛 » 传感器 » “EAGLE” brand LIQUID TIGHT FLEXIBLE CONDUIT
shjsrg9
shjsrg9   |   当前状态:离线
总积分:153  2025年可用积分:0
最后登录时间: 2008-07-13
shjsrg9  发表于 2008/7/13 12:23:46      915 查看 0 回复  [上一主题]  [下一主题]
Electric liquidtight flexible metal conduits,LT connectors
Aluminum liquidtight connectors for flexible conduits
Liquatite Flexible Metal Conduit
Flexible Metal Conduit, Liquid-tight
Electric liquidtight flexible metal conduit,connectors,fittings
electrical LiquidTight Flexible metal Conduit
Liquidtight Flexible Steel Conduit,connectors
Liquid Tight Flexible PVC Coated metal Conduit
Liquidtight flexible metal conduit
Liquidtight metal conduit is manufactured from an electro-galvanised steel flexible inner core which is pressure coated with an oil resistant, high temperature grade of plasticised PVC. The PVC is keyed into the corrugations of the inner steel flexible core, which prevents the PVC from wrinkling when the conduit is bent to its minimum bend radius. The PVC coating provides a smooth outer surface onto which liquid tight compression fittings can be secured.
Liquidtight metal conduit offers high mechanical strength combined with complete protection against liquids and dust. It is suitable for regular movements and vibration.
Liquidtight metal conduit is UV resistant since the PVC outer sheath incorporates a minimum of 0.9 % carbon black (for black) and chemical stabilisers (for grey and orange) and are therefore suitable for use outside. Liquidtight metal conduits are used in machine tool applications where liquid tight (IP66 & 67) protection is important, and also oil and/or temperature resistance. Liquidtight metal conduit may be used for external applications since it is both liquid tight and UV resistant.
Color Liquid-Tight Connectors
for more professional cable managements.
Machine grey LIQUIDTIGHT Flexible metallic conduits
Liquidtight Flexible steel Conduits and NEW ALUMINUM connectors
electrical LiquidTight Flexible Metal Conduit (LFMC)
( Protecting wiring in wet locations )
Liquid-tight conduit is ideal when used with liquid-tight fittings for applications where a high degree of liquid tightness is required.  This product is suitable for a number of general purpose wiring applications and ideal for environments with lots of water, coolant, and vibrations such as machine tool workshops.
Aluminum Liquid-tight Connectors
 This new line of connectors are made of high-quality forged aluminum for superior strength and durability. These unique configurations work perfectly with our whole range of flexible conduits and hoses. All forged connectors feature:
* All aluminum construction
* Totally re-useable
* Unique taper design for simple assembly and superior water tightness.
* Fixed or swivel type.
http://www.shjsrg.com
Flexible, sleek, with increased IP ratings, Liquid-tight flexible metallic conduit (LFMC) is suitable for use in a variety of environments and applications from general purpose wiring in wet or damp locations, to direct burial and in concrete embedment, to raised computer room floors and site lighting jobs.
conector recto hermetico,curvo 90
Liquid-tight zinc die cast connectors
Model: DMA,DMB
Available in 3/8 inch to 4 inch trade size
Zinc Die-cast construction
For use with both Metallic Liquid tight Conduit and Nonmetallic Liquid tight Type B
Resistant to outdoor weather conditions
Liquidtight/Raintight/OilTight
Suitable for wet locations
Suitable for grounding (through 1-1/4")
Locknut included
Computer Blue Liquid-tight Flexible steel Conduit
Computer Blue is a liquid-tight flexible steel conduit commonly used for computer room installations. The blue jacket color easily identifies circuitry for computer power wiring. It has a flexible inner core made from a spiral wound strip of heavy gauge, electro-galvanized steel. It contains an integral copper bonding wire.
Applications:
Liquid-tight flexible conduit provides protection for wiring circuits located in extremely wet or damp areas. This computer BLUE is especially suitable for wirings in computer rooms.
This conduit is intended for:
    -For use in exposed or concealed locations.
    -Installations under raised floors in Data Processing Areas.
    -Direct burial and in poured concrete.
