您的位置:控制工程论坛网论坛 » 教程与手册 » 走马灯 (C语言)
xilinxue
xilinxue   |   当前状态:在线
总积分:16186  2026年可用积分:0
最后登录时间: 2020-03-22
走马灯 (C语言)
xilinxue  发表于 2008/9/20 13:18:52      1545 查看 0 回复  [上一主题]  [下一主题]
#include <REG52.H>
unsigned char RunMode;
//**********************************System Fuction*************************************************
void Delay1ms(unsigned int count)
 unsigned int i,j;
 for(i=0;i<count;i++)
 for(j=0;j<120;j++);
unsigned char code LEDDisplayCode[] = { 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8, //0~7
                              0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xFF};
void Display(unsigned char Value)
 P3 = LEDDisplayCode[Value];
void LEDFlash(unsigned char Count)
 unsigned char i;
 bit Flag;
 for(i = 0; i<Count;i++)
  Flag = !Flag;
  if(Flag)
   Display(RunMode);
  else
   Display(0x10);
  Delay1ms(100);
 Display(RunMode);
unsigned char GetKey(void)
 unsigned char KeyTemp,CheckValue,Key = 0x00;
 CheckValue = P2&0x32;
 if(CheckValue==0x32)
  return 0x00;
 Delay1ms(10);
 KeyTemp = P2&0x32;
 if(KeyTemp==CheckValue)
  return 0x00;
 if(!(CheckValue&0x02))
  Key|=0x01;
 if(!(CheckValue&0x10))
  Key|=0x02;
 if(!(CheckValue&0x20))
  Key|=0x04;
 return Key;
unsigned int TimerCount,SystemSpeed,SystemSpeedIndex;
void InitialTimer2(void)
 T2CON  = 0x00;   //16 Bit Auto-Reload Mode
  TH2 = RCAP2H = 0xFC;   //重装值,初始值 TL2 = RCAP2L = 0x18;
 ET2=1;     //定时器 2 中断允许
 TR2 = 1;    //定时器 2 启动
 EA=1;
unsigned int code SpeedCode[]={   1,   2,   3,   5,   8,  10,  14,  17,  20,  30,
            40,  50,  60,  70,  80,  90, 100, 120, 140, 160,
        180, 200, 300, 400, 500, 600, 700, 800, 900,1000};//30
void SetSpeed(unsigned char Speed)
 SystemSpeed =SpeedCode[Speed];
void LEDShow(unsigned int LEDStatus)
 P1 = ~(LEDStatus&0x00FF);
 P0 = ~((LEDStatus>>8)&0x00FF);
void InitialCPU(void)
 RunMode = 0x00;
 TimerCount = 0;
 SystemSpeedIndex = 10;
 P1 = 0x00;
 P0 = 0x00;
 P2 = 0xFF;
 P3 = 0x00;
 Delay1ms(500);
 P1 = 0xFF;
 P0 = 0xFF;
 P2 = 0xFF;
 P3 = 0xFF;
 SetSpeed(SystemSpeedIndex);
 Display(RunMode);
//Mode 0
unsigned int LEDIndex = 0;
bit LEDDirection = 1,LEDFlag = 1;
void Mode_0(void)
 LEDShow(0x0001<<LEDIndex);
 LEDIndex = (LEDIndex+1)%16;
//Mode 1
void Mode_1(void)
 LEDShow(0x8000>>LEDIndex);
//Mode 2
void Mode_2(void)
 if(LEDDirection)
 else
 if(LEDIndex==15)
  LEDDirection = !LEDDirection;
//Mode 3
void Mode_3(void)
 if(LEDDirection)
  LEDShow(~(0x0001<<LEDIndex));
 else
  LEDShow(~(0x8000>>LEDIndex));
 if(LEDIndex==15)
//Mode 4
void Mode_4(void)
 if(LEDDirection)
  if(LEDFlag)
   LEDShow(0xFFFE<<LEDIndex);
     else
   LEDShow(~(0x7FFF>>LEDIndex));
 else
  if(LEDFlag)
   LEDShow(0x7FFF>>LEDIndex);
  else
   LEDShow(~(0xFFFE<<LEDIndex));
 if(LEDIndex==15)
  if(LEDDirection) LEDFlag = !LEDFlag;
//Mode 5
void Mode_5(void)
 if(LEDDirection)
  LEDShow(0x000F<<LEDIndex);
 else
  LEDShow(0xF000>>LEDIndex);
 if(LEDIndex==15)
//Mode 6
void Mode_6(void)
 if(LEDDirection)
  LEDShow(~(0x000F<<LEDIndex));
 else
  LEDShow(~(0xF000>>LEDIndex));
 if(LEDIndex==15)
//Mode 7
void Mode_7(void)
 if(LEDDirection)
  LEDShow(0x003F<<LEDIndex);
 else
  LEDShow(0xFC00>>LEDIndex);
 if(LEDIndex==9)
    LEDIndex = (LEDIndex+1)%10;
//Mode 8
void Mode_8(void)
 LEDShow(++LEDIndex);
void TimerEventRun(void)
 if(RunMode==0x00)
  Mode_0();
 else if(RunMode ==0x01)
  Mode_1();
 else if(RunMode ==0x02)
  Mode_2();
 else if(RunMode ==0x03)
  Mode_3();
 else if(RunMode ==0x04)
  Mode_4();
 else if(RunMode ==0x05)
  Mode_5();
 else if(RunMode ==0x06)
  Mode_6();
 else if(RunMode ==0x07)
  Mode_7();
 else if(RunMode ==0x08)
  Mode_8();
void Timer2(void) interrupt 5 using 3
 TF2 = 0;  //中断标志清除( Timer2 必须软件清标志!)
 if(++TimerCount>=SystemSpeed)
  TimerCount = 0;
  TimerEventRun();
unsigned char MusicIndex = 0;
void KeyDispose(unsigned char Key)
 if(Key&0x01)
  LEDDirection = 1;
  LEDIndex = 0;
  LEDFlag = 1;
  RunMode = (RunMode+1)%9;
  Display(RunMode);
 if(Key&0x02)
  if(SystemSpeedIndex>0)
   --SystemSpeedIndex;
  else
   LEDFlash(6);
 if(Key&0x04)
  if(SystemSpeedIndex<28)
   ++SystemSpeedIndex;
  else
   LEDFlash(6);
main()
 unsigned char Key;
 InitialCPU();
 InitialTimer2();
 while(1)
  Key = GetKey();
  if(Key!=0x00)
   KeyDispose(Key);
