您的位置:控制工程论坛网论坛 » 传感器 » Dwyer DDA 和 DDC非弹簧复位直接耦合驱动器
szdwyer
szdwyer   |   当前状态:在线
总积分:1783  2025年可用积分:0
最后登录时间: 2019-07-30
szdwyer  发表于 2008/9/22 11:03:14      886 查看 0 回复  [上一主题]  [下一主题]
产品名称:  DDA 和 DDC非弹簧复位直接耦合驱动器
产品型号:  DDA 和 DDC
Low Cost, Two-Position or Modulating
Power Requirements: DDA: 110 VAC, 24 VAC, ±10%, 50/60 Hz, single phase. Optional 230 VAC; DDC: 24 VAC, ±10%, 50/60 Hz, single phase.
Power Consumption: DDA: 110 VAC models: 5 VA, 230 VAC models: 5 VA, 24 VAC models: 3 VA; DDC: 4 VA.
Control Input: DDA: Two-position, floating; DDC: 4-20 mA or 0-10 VDC.
Overload Protection: Magnetic clutch.
Angle of Rotation: 95° (mechanically adjustable).
Fits Shaft Diameter: 0.4˝ (10 mm) or 0.5˝ (13 mm).
Position Indication: Visual indicator.
Direction of Rotation: CW/CCW.
Running Time: 17 in-lb, 35 in-lb, 53 in-lb: 110 sec.; 70 in-lb:160 sec.
Electrical Connection: Terminal block, 18 AWG.
Manual Override: Push button.
Temperature Limit: -22 to 122°F (-30 to 50°C).
Sound: <45 dB.
Life Expectancy: 60000 full cycles.
Housing: NEMA 2 (IP40).
Standard Accessories: (2) imitative baffles, (2) baffle setscrews, (1) actuator body setscrew, and (1) aluminum gasket.
Weight: 1.72 lb (0.78 kg).
型号描述
模拟控制
DDC13Non-spring return direct coupled actuator, size/torque 17 in-lb (2 N m), 24 VAC.
DDC23Non-spring return direct coupled actuator, size/torque 35 in-lb (4 N m), 24 VAC.
DDC33Non-spring return direct coupled actuator, size/torque 53 in-lb (6 N m), 24 VAC.
DDC43Non-spring return direct coupled actuator, size/torque 70 in-lb (8 N m), 24 VAC.
浮点控制
DDA11Non-spring return direct coupled actuator, size/torque 17 in-lb (2 N m), 110 VAC.
DDA13Non-spring return direct coupled actuator, size/torque 17 in-lb (2 N m), 24 VAC.
DDA21Non-spring return direct coupled actuator, size/torque 35 in-lb (4 N m), 110 VAC.
DDA23Non-spring return direct coupled actuator, size/torque 35 in-lb (4 N m), 24 VAC.
DDA31Non-spring return direct coupled actuator, size/torque 53 in-lb (6 N m), 110 VAC.
DDA33Non-spring return direct coupled actuator, size/torque 53 in-lb (6 N m), 24 VAC.
DDA41Non-spring return direct coupled actuator, size/torque 70 in-lb (8 N m), 110 VAC.
DDA43Non-spring return direct coupled actuator, size/torque 70 in-lb (8 N m), 24 VAC.
