您的位置:控制工程论坛网论坛 » 现场总线 » Modbus 通讯协议编程(3) [完]
zhiy66
zhiy66   |   当前状态:在线
总积分:6528  2025年可用积分:0
最后登录时间: 2012-01-11
zhiy66  发表于 2009/10/10 11:02:48      1506 查看 3 回复  [上一主题]  [下一主题]
'RTU校验
Private Sub RTUcheck()
        Dim CRC() As Byte
        Dim d(5) As Byte
        Dim string1 As String
        Dim j As Integer, chrlength As Integer, temp As String
        string1 = Text1text
        chrlength = Len(string1)
        For j = 0 To chrlength / 2 - 1
                  temp = Mid(string1, j * 2 + 1, 2)
                  d(j) = Val("&H" & temp)
        Next
        RTUCRC = CRC16(d)                         '调用CRC16计算函数, CRC(0)为高位,  CRC(1)为低位
        Text1text = Text1text & RTUCRC
End Sub
Private Sub incorporate()                                       '将输入的十进制从机地址、命令、资料地址和资料内容合并成字符串
       Dim wholechar As String, wc%, wcyc%, wchar As String
       Dim SID As String, Cmd As String, InfoAdd As String, data As String
       Dim SIDnum%, Cmdnum%, InfoAddNum%, Datanum%
      On Error Resume Next
        wholechar = CStr(Combo6.Text) & CStr(Text6.Text) & CStr(Text7.Text) & CStr(Text8.Text)
        wc = Len(wholechar)
        For wcyc = 1 To wc
            wchar = Mid(wholechar, wcyc, 1)
            If InStr("0123456789", wchar) = 0 Then
                MsgBox "输入错误,请重新输入", , "错误提示"
                Exit Sub
            End If
        Next
             SIDnum = Len(CStr(Hex(Combo6.Text)))
              Select Case SIDnum
              Case 0
                Exit Sub
             Case 1
                 SID = "0" & CStr(Hex(Combo6.Text))
             Case 2
                 SID = CStr(Hex(Combo6.Text))
             End Select
             Cmdnum = Len(CStr(Hex(Text6.Text)))
             Select Case Cmdnum
             Case 0
                Exit Sub
             Case 1
                  Cmd = "0" & CStr(Hex(Text6.Text))
             Case 1
                  Cmd = CStr(Hex(Text6.Text))
             End Select
             InfoAddNum = Len(CStr(Hex(Text7.Text)))
             Select Case InfoAddNum
             Case 0
                Exit Sub
             Case 1
                  InfoAdd = "000" & CStr(Hex(Text7.Text))
             Case 2
                  InfoAdd = "00" & CStr(Hex(Text7.Text))
             Case 3
                  InfoAdd = "0" & CStr(Hex(Text7.Text))
             Case 4
                  InfoAdd = CStr(Hex(Text7.Text))
            End Select
             Datanum = Len(CStr(Hex(Text8.Text)))
             Select Case Datanum
             Case 0
                Exit Sub
             Case 1
                  data = "000" & CStr(Hex(Text8.Text))
             Case 2
                  data = "00" & CStr(Hex(Text8.Text))
             Case 3
                  data = "0" & CStr(Hex(Text8.Text))
             Case 4
                  data = CStr(Hex(Text8.Text))
            End Select
           If Err Then                                                          '显示出错信息
               MsgBox Error$, 48, "错误信息"
                Exit Sub
           End If
            Text1text = CStr(SID) & CStr(Cmd) & CStr(InfoAdd) & CStr(data)
End Sub
Private Sub incorporate1()                                       '将输入的十进制从机地址、命令、资料地址和资料内容合并成字符串
        wholechar = CStr(Combo6.Text) & CStr(Text7.Text) & CStr(Text8.Text)
        wc = Len(wholechar)
        For wcyc = 1 To wc
                Exit Sub
            End If
        Next
              Select Case SIDnum
              Case 0
                Exit Sub
             Case 1
             Case 2
             End Select
            'Cmdnum = Len(CStr(Hex(Text6.Text)))
             'Select Case Cmdnum
             'Case 0
             '   Exit Sub
             'Case 1
             '     Cmd = "0" & CStr(Hex(Text6.Text))
             'Case 1
             '     Cmd = CStr(Hex(Text6.Text))
             'End Select
             Case 0
                Exit Sub
             Case 1
             Case 2
            End Select
             Select Case Datanum
             Case 0
                Exit Sub
             Case 1
             Case 2
             Case 3
             Case 4
            End Select
           If Err Then                                                          '显示出错信息
                Exit Sub
           End If
            If Option11.value Then
                  Cmd = "08"
             Else
                  Cmd = "07"
            End If
End Sub
Private Function CRC16(data() As Byte) As String
      Dim CRC16Lo As Byte, CRC16Hi As Byte      'CRC寄存器
      Dim CL As Byte, CH As Byte                '多项式码&HA001
      Dim CRCLo As String, CRCHi As String
      Dim SaveHi As Byte, SaveLo As Byte
      Dim i As Integer
      Dim Flag As Integer
      CRC16Lo = &HFF
      CRC16Hi = &HFF
      CL = &H1
      CH = &HA0
      For i = 0 To UBound(data)
        CRC16Lo = CRC16Lo Xor data(i) '每一个数据与CRC寄存器进行异或
        For Flag = 0 To 7
          SaveHi = CRC16Hi
          SaveLo = CRC16Lo
          CRC16Hi = CRC16Hi \ 2            '高位右移一位
          CRC16Lo = CRC16Lo \ 2            '低位右移一位
          If ((SaveHi And &H1) = &H1) Then '如果高位字节最后一位为1
            CRC16Lo = CRC16Lo Or &H80      '则低位字节右移后前面补1
          End If                           '否则自动补0
          If ((SaveLo And &H1) = &H1) Then '如果LSB为1,则与多项式码进行异或
            CRC16Hi = CRC16Hi Xor CH
            CRC16Lo = CRC16Lo Xor CL
          End If
        Next Flag
      Next i
      If Len(Hex(CRC16Hi)) = 1 Then
         CRCHi = "0" + Hex(CRC16Hi)
      Else
         CRCHi = Hex(CRC16Hi)
      End If
      If Len(Hex(CRC16Lo)) = 1 Then
         CRCLo = "0" + Hex(CRC16Lo)
      Else
         CRCLo = Hex(CRC16Lo)
      End If
         CRC16 = CRCLo + CRCHi
  End Function
