您的位置:控制工程论坛网论坛 » 传感器 » Dwyer STC系列管道安装式双金属温度计
szdwyer
szdwyer   |   当前状态:在线
总积分:1783  2025年可用积分:0
最后登录时间: 2019-07-30
szdwyer  发表于 2008/9/23 13:09:16      1008 查看 0 回复  [上一主题]  [下一主题]
产品名称:  STC系列管道安装式双金属温度计
产品型号:  STC
技术指标
精度:
±2%.
分辨率: 小于满量程的4% .
环境温度: 14 302°F (-10 to 150°C).
刻度盘尺寸: 2˝.
镜面: 玻璃.
接液材质: .
重量: 3.4 oz (95 g).
型号描述
STC151Pipe-mount bimetal surface thermometer, range -50 to 250°F, 3/4" to 7/8" spring.
 STC141Pipe-mount bimetal surface thermometer, range 0 to 150°F, 3/4" to 7/8" spring.
 STC161Pipe-mount bimetal surface thermometer, range 70 to 370°F, 3/4" to 7/8" spring.
 STC171Pipe-mount bimetal surface thermometer, range 70 to 500°F, 3/4" to 7/8" spring.
 STC152Pipe-mount bimetal surface thermometer, range -40 to 120°C, 3/4" to 7/8" spring.
 STC162Pipe-mount bimetal surface thermometer, range 20 to 180°C, 3/4" to 7/8" spring.
 STC172Pipe-mount bimetal surface thermometer, range 20 to 260°C, 3/4" to 7/8" spring.
 STC351Pipe-mount bimetal surface thermometer, range -50 to 250°F, 1" to 1-5/8" spring.
 STC341Pipe-mount bimetal surface thermometer, range 0 to 150°F, 1" to 1-5/8" spring.
 STC361Pipe-mount bimetal surface thermometer, range 70 to 370°F, 1" to 1-5/8" spring.
 STC371Pipe-mount bimetal surface thermometer, range 70 to 500°F, 1" to 1-5/8" spring.
 STC352Pipe-mount bimetal surface thermometer, range -40 to 120°C, 1" to 1-5/8" spring.
 STC362Pipe-mount bimetal surface thermometer, range 20 to 180°C, 1" to 1-5/8" spring.
 STC372Pipe-mount bimetal surface thermometer, range 20 to 260°C, 1" to 1-5/8" spring.
 STC451Pipe-mount bimetal surface thermometer, range -50 to 250°F, 1-5/8" to 2-3/8" spring.
 STC441Pipe-mount bimetal surface thermometer, range 0 to 150°F, 1-5/8" to 2-3/8" spring.
 STC461Pipe-mount bimetal surface thermometer, range 70 to 370°F, 1-5/8" to 2-3/8" spring.
 STC471Pipe-mount bimetal surface thermometer, range 70 to 500°F, 1-5/8" to 2-3/8" spring.
 STC452Pipe-mount bimetal surface thermometer, range -40 to 120°C, 1-5/8" to 2-3/8" spring.
 STC462Pipe-mount bimetal surface thermometer, range 20 to 180°C, 1-5/8" to 2-3/8" spring.
 STC472Pipe-mount bimetal surface thermometer, range 20 to 260°C, 1-5/8" to 2-3/8" spring.
