shirley1010 | 当前状态:在线
总积分:998 2026年可用积分:0
最后登录时间: 2019-06-16
体验错误,感悟成长
shirley1010 发表于 2008/10/9 11:23:27 1056 查看 0 回复 [上一主题] [下一主题]
There are at least four different types of mistakes and what you learn from them may depend on your maturity as well as the type of mistake you made.
The first type of mistake is the dumb mistake. This is the mistake of tripping on the sidewalk or touching wet paint. This is the child running from a promised spanking and hiding under the bed. About the only lessons which can be learned from a dumb mistake is that it was dumb to do it, but that doesn’t mean it will never happen again or that you’ve learned anything from the mistake. After all, there will always be rough spots on the sidewalk and we always have that uncontrollable urge to see if the “wet paint” sign is right.
Mistake number two is the simple mistake. This is the mistake where you call your wife by your secretary’s name, or you forget to mail the letter with the rent check. If something like this happens regularly, or if it becomes an issue between yourself and your spouse, you probably need to find a way to remember errands and names. If it’s simply a lack of focus, it’s probably best not to stress out about it. You can learn from this type of mistake that you can be better organized or that you may need to learn some memory techniques.
The third type of mistake is a little more serious. This is the dumb mistake or the simple mistake repeated over and over with either no understanding that it is a mistake, or no understanding of how to change and learn from the mistake so as to get different results the next time. This kind of mistake is known as the serious mistake. This mistake is one that could and should result in a change of thinking. If you lose your job because you are habitually late for work, you can refuse to accept the responsibility for the mistake and refuse to change, or you can continue to be the emotionally immature child who can’t learn from a mistake because they don’t understand that a mistake has been made. Either that or they blame the boss for firing them.
The fourth type of mistake is the most interesting, and also the one from you have the most opportunity to learn. This is the complex mistake. It may be the mistake that was unavoidable given all the sequence of events which led up to the error. This is where the learning comes in. By analyzing the causes, timing, personalities and nature of the mistake, you may recognize that the mistake was simply unavoidable, but you might also be able to use that information to react differently during the process and thereby reach a different result.
