caizhengsuo | 当前状态:在线
总积分:3196 2025年可用积分:0
最后登录时间: 2015-10-16
C语言可变参数函数使用总结
caizhengsuo 发表于 2008/10/14 9:15:09 686 查看 0 回复 [上一主题] [下一主题]
C语言可变参数函数使用总结
void TestFun(char* fmt,...)
int ch;
char selch = 0;
va_list ap = NULL;
va_start(ap, fmt);
do
selch = *fmt;
if (selch!='%')
putchar(*fmt);
else
selch = *++fmt;
switch(selch)
case 'c':
ch = va_arg(ap, int);
printf("%c",ch);
break;
case 'd':
ch = va_arg(ap,int);
printf("%d",ch);
break;
case 'x':
printf("%#x",ch);
break;
++fmt;
}while(*fmt!='\0');
va_end(ap);
//调用
TestFun((char*)"this is %d,%c,%x",1234,'6',0x12345);
//WIN-TC编译通过
#i nclude <stdarg.h>
typedef void *va_list;
#define va_start(ap, parmN) (ap = ...)
#define va_arg(ap, type) (*((type *)(ap))++)
#define va_end(ap)
void TestFun(cosnt char* fmt,...)
int ch;
long i32value = 0;
char selch = 0;
va_list ap = 0;
va_start(ap, fmt);
do
selch = *fmt;
if (selch!='%')
putch(*fmt);
else
selch = *++fmt;
switch(selch)
case 'c':
printf("%c",ch);
break;
case 'd':
printf("%d",ch);
break;
case 'x':
printf("%#x",ch);
break;
case 'l':
if(*++fmt== 'd')
i32value = va_arg(ap, long);
printf("%ld",i32value);
else
putch('l');
if(*fmt!=0)
putch(*fmt);
break;
default:
break;
++fmt;
}while(*fmt!='\0');
va_end(ap);
void main(void)
TestFun("this is %d,%c,%x,%ld",1234,'6',0x2345,(long)12345678);
getch();
void main(void)
TestFun("this is %d,%c,%x,%ld",1234,(char)'6',0x2345,(long)12345678);
getch();
上述的example使用宏定义, var_start(ap, pareN),var_arg(ap,type),var_end(ap).
var_start(ap, pareN) //是ap指向第一个变参.
var_arg(ap,type),//返回变参的实际值.
var_end(ap).//是ap指向空指针.
具体的实现,在不同的编译环境下有所不同.
