您的位置:控制工程论坛网论坛 » 嵌入式系统 » 转到linux下做PCB
caizhengsuo
caizhengsuo   |   当前状态:在线
总积分:3196  2025年可用积分:0
最后登录时间: 2015-10-16
转到linux下做PCB
caizhengsuo  发表于 2008/10/16 9:41:25      728 查看 0 回复  [上一主题]  [下一主题]
转到linux下做PCB
下载地址 ed2k://|file|Base_SPB155.md5|418|099FDAFDC400AF42FB67BC5BF0F48709|h=5Y6IRQQV4GZALBQ6WM6K2TJ4TWKC7PTR|/ ed2k://|file|Base_SPB155_license.lic|4417|9B199204E91D2EDDB92F735BF4252867|h=5QZV3ZHIWSXFEU6X4BOCFBFMEQDSVEAT|/ ed2k://|file|Base_SPB155_lnx86_1of5.tar|385138176|D910778AE0ECC61737302C76E6057ABC|h=MC5HMZP2PW3OJBJTWEAHFVUHTOYHVVEK|/ ed2k://|file|Base_SPB155_lnx86_2of5.tar|559300096|523E2131409905281E6B5258FACBBA15|h=N2Q4V4FWNYBC3QOETLZRBQQO6GHOTOTT|/ ed2k://|file|Base_SPB155_lnx86_3of5.tar|562261504|F50832E3CFFE58B7FB63393DADECC171|h=MQ6HHIDBHRHEJOOEGK6DZVK4GYGVISSS|/ ed2k://|file|Base_SPB155_lnx86_4of5.tar|556144640|0CDBFA4E44044B5092FD814414EE6D5C|h=6IULH7ZJI4GQPAKNOY4DYOQD74PLNKNE|/ ed2k://|file|Base_SPB155_lnx86_5of5.tar|18953728|EEA2EF952BAC328A44807836CDB7555B|h=ZRNRPB43LVWHPGQJXSY64TPK5HGY3Z7D|/ _________________ SPB15.5的安装(libc要有低于2.3.6的版本) cd cdrom1/E024_SPB155_ln86_1of5 ./SETUP.SH 出现 Specify path of install directory [OR type [RETURN] to exit]: 输入/opt/spb 出现 Directory /opt/spb does not exist. Create? [y/n]: y Do you want to use InstallScape [y/n]:n Specify path of install directory [OR type [RETURN] to exit]: 回车 cd /opt/spb/install/bin.lnx86 ./softload 开始安装选1-1-2-cdrom1/E024_SPB155_ln86_1of5 出现 Please press y (yes) or n (no) : no 选 4) Cadence Catalog 再选a 再选y 出现 Your package selections require SPB155 lnx86 P/N 356-73303-0102 CDROM # 2. 1) 2) 3) SPB155 lnx86 P/N 356-73303-0102 CDROM # 2 already mounted on /home/chenqs/cdrom1/E024_SPB155_ln86_1of5, continue. 4) Change CD-ROM mount point. m) Main Menu Type your choice: 选责4出现 You must now identify where the CD-ROM is mounted. 1) Local (mounted to this machine) 在选1出现 Specify the CD-ROM mount point 1) /cdrom 2) Other 选2写入你2盘的位置就ok了。装好后 cd /opt/spb/install ln -s tools.lnx86 tools 以候运行空格 .空格 bashrc就可以了 allegro &allegro_design_entry_HDL &projmgr &用于起动程序. Cadence.Allegro.v13.6 之后就改名叫PSD了,后来又改名叫SPB. fc4 的tar和安装不兼容会出The following tar errors were detected: 装过程是 ./SETUP.SH 1)装载可供使用的产品你必须现在识别CD-ROM在什么地方被安装。 1)本地(安装到这台机器) 2)远程(安装到另一个机器) m)主要的菜单 h)帮助 打出你的选择: [ 1 ] 规定CD-ROM安装点 1) / cdrom 2)其它 m)主要的菜单 p)以前的菜单 h)帮助 打出你的选择: [ 2 ] 2 从CD#1摘录安装信息。 你想要察看自述文件吗? 请压y (是)或者n (没有): n 安装信息是在什么地方? 1) (难以获得的选择)工作秩序 2)电子邮件文件 3)磁带 4)计算机辅助设计目录 5)文件目录 h)帮助 p)以前的菜单 q)退出 打出你的选择: [ 4 ] a)所有上述 n)没有上述 p)以前的菜单打出你的选择( a,n,p,1-3,2 5 9 ... ):a 你不有选择任何产品。正确的这吗? [ y与n ]请压y (是)或者n (没有):你的选择是正确的吗? [ y与n ] 请压y (是)或者n (没有) :y 产生详尽的设施数据... 确定可供使用的盘空间确定需要的盘空间 如果出SL-13是:安装选择的不足的盘空间。装好后 ln -s tools.lnx86 tools /opt/psb/tools/pcb/bin/allegro.exe 我的bashrc如下 # Cadence PSD environment icq 111290069 export CDS_INST_DIR=/opt/psb export CDS_LIC_FILE=$CDS_INST_DIR/share/cadence.license export CDS_DIR=$CDS_INST_DIR export CONCEPT_INST_DIR=$CDS_DIR export CDS_SITE=$CDS_DIR/share/local/ export LD_LIBRARY_PATH=$LD_LIBRARY_PATHCONCEPT_INST_DIR/tools/lib export CDSDOC_PROJECT=/CDS_INST_DIR/doc PATH=/opt/spb/tools/jre/binCONCEPT_INST_DIR/tools/binCONCEPT_INST_DIR/tools/pcb/bin:$CONCEPT_INST_DIR/tools/fet/bin:$PATH 装好了 cd /opt/spb/share/library tar -xzvf *.Z 这样projmgr就有零件了由于接触和使用较早等原因,国内的Protel用户为数众多,他们在选择Cadence高速PCB解决方案的同时,都面临着如何将手头的Protel设计移植到Cadence PCB设计软件中的问题。转到linux下做PCB 由于接触和使用较早等原因,国内的Protel用户为数众多,他们在选择Cadence高速PCB解决方案的同时,都面临着如何将手头的Protel设计移植到Cadence PCB设计软件中的问题。  在这个过程当中碰到的问题大致可分为两种:一是设计不很复杂,设计师只想借助Cadence CCT的强大自动布线功能完成布线工作;二是设计复杂,设计师需要借助信噪分析工具来对设计进行信噪仿真,设置线网的布线拓扑结构等工作。  对于第一种情况,要做的转化工作比较简单,可以使用Protel或Cadence提供的Protel到CCT的转换工具来完成这一工作。对于第二种情况,要做的工作相对复杂一些,下面将这种转化的方法作一简单的介绍。 chenqs@clo.com.cn   Cadence信噪分析工具的分析对象是Cadence Allegro的brd文件,而Allegro可以读入合乎其要求的第三方网表,Protel输出的Telexis格式的网表满足Allegro对第三方网表的要求,这样就可以将Protel文件注入Allegro。  这里有两点请读者注意。首先,Allegro第三方网表在$PACKAGE段不允许有“.”;其次,在Protel中,我们用BasName[0:N]的形式表示总线,用BasName[x]表示总线中的一根信号,Allegro第三方网表中总线中的一根信号的表示形式为Bas NameX,读者可以通过直接修改Protel输出的Telexis网表的方法解决这些问题。  Allegro在注入第三方网表时还需要每种类型器件的设备描述文件Device.txt文件,它的格式如下: Package: package type Class: classtype Pincount: total pinnumber Pinused: ...   其中常用的是PACKAGE,CLASS,PINCOUNT这几项。PACKAGE描述了器件的封装,但Allegro在注入网表时会用网表中的PACKAGE项而忽略设备描述文件中的这一项。CLASS确定器件的类型,以便信噪分折,Cadence将器件分为IC,IO,DISCRETE三类。PINCOUNT说明器件的管脚数目。对于大多数器件,Device.txt文件中包含有这三项就足够了。  有了第三方网表和设备描述文件,我们就可以将Protel中原理图设计以网表的形式代入到Cadence PCB设计软件中,接下来,设计师就可以借助Cadence PCB软件在高速高密度PCB设计方面的强大功能完成自己的设计。  如果已经在Protel作了PCB布局的工作,Allegro的script功能可以将Protcl中的布局在Allegro中重现出来。在Protel中,设计师可以输出一个Place & Pick文件,这个文件中包含了每个器件的位置、旋转角度和放在PCB顶层还是底层等信息,可以通过这个文件很方便的生成一个Allegro的script文件,在Allegro中执行这个script就能够重现Protel中的布局了,下面给出了完成Place & Pick文件到Allegro Script文件转化的C++代码,笔者使用这段代码,仅用了数分钟就将一个用户有800多个器件的PCB板布局在Allegro重现出来。 FILE *fp1, *fp2; ::AfxMessageBox("hello"); fp1=fopen("pick.txt", "rt"); if (fp1==NULL) ::AfxMessageBox("Can not open the file!!!"); fp2=fopen("place.txt","wt"); if (fp2==NULL) ::AfxMessageBox("Can not create the file!!!"); char refdes[5], Pattern[5]; float midx,midy,refx,refy,padx,pady,rotation; char tb[1]; char tmp='"'; fprintf(fp2,"%s ", "# Allegro script"); fprintf(fp2,"%s ", "version 13.6"); fprintf(fp2,"%s ", "place refdes"); while (!feof(fp1)) { fscanf(fp1,"%s", refdes); fscanf(fp1,"%s", Pattern); fscanf(fp1,"%f", &midx); fscanf(fp1,"%f", &midy); fscanf(fp1,"%f", &refx); fscanf(fp1,"%f", &refy); fscanf(fp1,"%f", &padx); fscanf(fp1,"%f", &pady); fscanf(fp1,"%s", tb); fscanf(fp1,"%f", &rotation); fprintf(fp2, "fillin %c%s%c ",tmp,refdes,tmp); if (rotation!=0) { fprintf(fp2, "rotate "); fprintf(fp2, "iangle %f ", rotation); }; char yy=tb[0]; if (yy!='T') fprintf(fp2, "pop mirror "); fprintf(fp2, "pick %f %f ", padx,pady); fprintf(fp2, "next "); }; fprintf(fp2, "done"); fclose(fp1); fclose(fp2); 以上简单介绍了Protel到 SPB152转化的方法,希望能对读者的设计工作有所帮助。'
