您的位置:控制工程论坛网论坛 » 产品供求 » FMTC open sources EtherCAT master library开发组件
water
water   |   当前状态:离线
总积分:882  2025年可用积分:0
最后登录时间: 2007-01-25
water  发表于 2008/8/16 7:41:54      81273 查看 475 回复  [上一主题]  [下一主题]
The Flanders Mechatronics Technology Centre has decided to release
  their EtherCAT master implementation as open source software. The
  EtherCAT master library, together with its technical documentation can
  be obtained from http://ethercatmaster.berlios.de. Technical discussions
  and patches are welcomed on the mailing list, accessible from the same
  website.
  “When we started our investigation of Ethernet fieldbus systems two
  years ago, EtherCAT was still an upcoming technology”, explains Bob
  Koninckx, program manager at FMTC. “We saw, however, great potential
  for Motion Control applications. Also the possibility to use CANopen as
  the application layer, allowing for an easy upgrade of existing CAN-based
  applications was much appreciated”, he continues.
  FMTC member companies are machine builders, active in very specialized
  markets, like textile, sheet metal working, agriculture etc. Often they build
  their own control solution, simply because they can not find solutions that
  meet their needs on the market. A fieldbus, regardless of its technical
  merits, that can not be easily integrated with their in-house developed
  controllers, will therefore never be interesting to them. “In order to
  assess the usefulness of EtherCAT for our member companies, we were
  more or less obliged to make our own implementation”, Bob Koninckx
  says.
  “We were pleased that our steering committee agreed with the above
  ideas and allowed us to release our EtherCAT master implementation as
  open source software at the end of the project. Also the support we got
  from the EtherCAT Technology Group was much appreciated”, he adds.
  In his opinion, this was one of the strongest arguments they could possibly
  make to prove that EtherCAT indeed is an open technology.
  Martin Rostan, Executive Director of the EtherCAT Technology Group:
  “The FMTC open source EtherCAT master library is a most welcome
  enhancement to the EtherCAT technology offering. It provides EtherCAT
  connectivity to the open source community and will contribute to the
  success story of our high performance Ethernet- based fieldbus system.
  The concerns that open source projects might dilute conformance with
  the standard were met by careful additions to the GNU public license:
  code developed in this project has to remain compatible with the
  EtherCAT specs and a valid EtherCAT implementation.”
  “The software has been written for and has been tested with the eCos
  operating system (http://ecos.sourceware.org)”, explains Klaas Gadeyne,
  FMTC’s lead developer of the library. “It has however been written with
  portability in mind. We did our best to limit the dependencies on the
  operating system to a bare minimum and localized them in only a few files.
  Porting to another operating requires as little as 700 lines of source code
  to be inspected and possibly modified”, he continues.
  “I think we provided something useful”, Bob Koninckx concludes. “The
  sources are now available. I really hope that the project will pick up and
  that people will start using them, improving them, porting them and
  contribute their modifications.”
总共 , 当前 /, 12345678910... 48【下一页】
