您的位置:控制工程论坛网论坛 » 传感器 » 美国吉时利仪器公司 Keithley Instruments 半导体电容-电压(C-V)测试技术、
hjhbcc
hjhbcc   |   当前状态:离线
总积分:0  2025年可用积分:0
hjhbcc  发表于 2008/10/22 10:57:29      1068 查看 0 回复  [上一主题]  [下一主题]
Webcast 半导体电容-电压(C-V)测试技术、窍门和必备知识:
Tips, Tricks, and Traps of Semiconductor Capacitance-Voltage (C-V) Testing
Live Webcast:
Date: Thursday, June 26, 2008
Time: 15:00 CEST/ 9:00 AM EDT
Duration: 1 Hour
Joining The Event:
You may log-in to the seminar 15 minutes prior to the start time on the date listed below. To join the live event by click on the Event URL below and enter your email address to log-in.
Event URL:
http://w.on24.com/r.htm?e=111536&s=1&k=94325AE64417B69492BB57E0418124CE
We look forward to your participation. Thank you. Keithley Instruments
Important: System Setup & Compatibility Check
Test the computer that you will be using and make sure you have the minimum technical requirements to attend this event. Allow sufficient time prior to the event for this test. Test at http://webcast.on24.com/view/help/ehelp.html
