您的位置:控制工程论坛网论坛 » 教程与手册 » DSP281X硬件SPI读写一体化C++函数(驱动74hc595)
常青树
常青树   |   当前状态:在线
总积分:1421  2026年可用积分:0
最后登录时间: 2012-05-30
常青树  发表于 2008/10/31 7:38:12      1425 查看 0 回复  [上一主题]  [下一主题]
void SystemObj::InitSpi(void)
    EALLOW;
    GpioMuxRegs.GPFMUX.all |= 0x000F;    // Select GPIOs to be SPI pins
                                     // Port F MUX - x000 0000 0000 1111
      EDIS;
// Initialize SPI FIFO registers
    SpiaRegs.SPIFFTX.all=0xE040;
    SpiaRegs.SPIFFRX.all=0x204f;
    SpiaRegs.SPIFFCT.all=0x0;
      SpiaRegs.SPICCR.all =0x0008;                 // Reset on, rising edge, 8-bit char bits
      SpiaRegs.SPICTL.all =0x0006;                 // Enable master mode, normal phase,
                                                 // enable talk, and SPI int disabled.
      SpiaRegs.SPIBRR =0x007F;
    SpiaRegs.SPICCR.all =0x009F;                 // Relinquish SPI from Reset
    SpiaRegs.SPIPRI.bit.FREE = 1;                // Set so breakpoints don't disturb xmission
    //(CLKPOLARITY,CLK_PHASE )01 10支持74HC595,00或11不支持  测试通过
    SpiaRegs.SPICCR.bit.CLKPOLARITY = 1;
    SpiaRegs.SPICTL.bit.CLK_PHASE = 0;
      System.SpiReadWrite(0xff);//LED数码管灭
    //发送595锁存脉冲信号RCLK
      SpiRclkRegs = 0;
      SpiRclkRegs = 1;
//硬件SPI读写一体化函数
unsigned char SystemObj::SpiReadWrite(unsigned char cData)
      SpiaRegs.SPITXBUF = cData;
    // Wait until data is received
      while(SpiaRegs.SPIFFRX.bit.RXFFST !=1)
//        KickDog();//喂狗测试
    // Check against sent data
      return SpiaRegs.SPIRXBUF;
//数码管
#define LedSegA  0x01
#define LedSegB  0x02
#define LedSegC  0x04
#define LedSegD  0x08
#define LedSegE  0x10
#define LedSegF  0x20
#define LedSegG  0x40
#define LedSegH  0x80
#define LedSegA  0x80
#define LedSegB  0x40
#define LedSegC  0x20
#define LedSegD  0x10
#define LedSegE  0x08
#define LedSegF  0x04
#define LedSegG  0x02
#define LedSegH  0x01
#define LedChar0 (LedSegA + LedSegB + LedSegC + LedSegD + LedSegE + LedSegF          )
#define LedChar1 (          LedSegB + LedSegC                                        )
#define LedChar2 (LedSegA + LedSegB           + LedSegD + LedSegE           + LedSegG)
#define LedChar3 (LedSegA + LedSegB + LedSegC + LedSegD                     + LedSegG)
#define LedChar4 (          LedSegB + LedSegC                     + LedSegF + LedSegG)
#define LedChar5 (LedSegA           + LedSegC + LedSegD           + LedSegF + LedSegG)
#define LedChar6 (LedSegA           + LedSegC + LedSegD + LedSegE + LedSegF + LedSegG)
#define LedChar7 (LedSegA + LedSegB + LedSegC                                        )
#define LedChar8 (LedSegA + LedSegB + LedSegC + LedSegD + LedSegE + LedSegF + LedSegG)
#define LedChar9 (LedSegA + LedSegB + LedSegC + LedSegD           + LedSegF + LedSegG)
#define LedCharA (LedSegA + LedSegB + LedSegC           + LedSegE + LedSegF + LedSegG)
#define LedCharB (                    LedSegC + LedSegD + LedSegE + LedSegF + LedSegG)
#define LedCharC (LedSegA                     + LedSegD + LedSegE + LedSegF          )
#define LedCharD (          LedSegB + LedSegC + LedSegD + LedSegE           + LedSegG)
#define LedCharE (LedSegA                     + LedSegD + LedSegE + LedSegF + LedSegG)
#define LedCharF (LedSegA                               + LedSegE + LedSegF + LedSegG)
interrupt void ISRTimer2(void)
//以下定义为共阳数码管
static const unsigned char LedTab[] =
{//显示字符表存放在ROM中
  LedChar0, LedChar1, LedChar2, LedChar3,
  LedChar4, LedChar5, LedChar6, LedChar7,
  LedChar8, LedChar9, LedCharA, LedCharB,
  LedCharC, LedCharD, LedCharE, LedCharF
    System.SpiReadWrite(~LedTab[Timer.Count2 & 0x0f]);//硬件SPI读写一体化函数
    Timer.Count2++;
//发送595锁存脉冲信号RCLK
    SpiRclkRegs = 0;
    SpiRclkRegs = 1;
//数码管
