您的位置:控制工程论坛网论坛 » 传感器 » 二、温度测量仪表 Temperature measuring instrument
skbolo
skbolo   |   当前状态:在线
总积分:2158  2025年可用积分:0
最后登录时间: 2015-01-22
skbolo  发表于 2006/6/27 18:14:30      1223 查看 0 回复  [上一主题]  [下一主题]
  工业双金属温度计 Industrial bimetallic thermometer
  玻璃水银温度计 Mercury-in-glass thermometer
  电接点压力温度计 Manometric thermometer with electric contacts
  光学温度计 Optical pyrometer
  表面热电偶 Surface thermocouple
  镍铬-镍硅热电偶 Chromel-silicel thermocouple
  镍铬-镍铝热电偶 Chromel-alumel thermocouple
  铂铑-铂热电偶 Platinum-rhodium platinum thermocouple
  固定螺纹(普通式) 镍铬-镍铝热电偶 Chromel-alumel thermocouple with fixed threaded bushing
  固定螺纹(防溅式) 镍铬-镍铝热电偶 Splash-proof chromel-alumel thermocouple with fixed threaded bushing
  双支热电偶 Twin thermocouple
  铠装热电偶 Armored thermocouple
  铂热电阻 Platinum resistance thermometer
  表面热电阻 Surface resistance thermometer
  可动法兰普通式铂热电阻 Platinum resistance thermometer with movable flange
  温包 Thermal bulb
