您的位置:控制工程论坛网论坛 » 传感器 » 四、流量、液位测量仪表 Flow & level measuring instruments
skbolo
skbolo   |   当前状态:在线
总积分:2158  2025年可用积分:0
最后登录时间: 2015-01-22
skbolo  发表于 2006/6/27 18:18:05      1250 查看 0 回复  [上一主题]  [下一主题]
  椭圆齿轮流量计 Ovalgear flowmeter
  湿式气体流量计 Wet type gas flowmeter
  气远传转子流量计 Pneumatic remote transmitting rotameter
  靶式流量计 Target flowmeter
  玻璃转子流量计 Glass type rotameter
  玻璃管液面计 Glass-tube level gauge
  浮标式遥控测液位计 Remote measuring float level meter
  环室标准孔板 Standard orifice with carrier-rings
  带柄平孔板 Plate orifice with handle
  组合式高压孔板 Assemble type HP orifice
  环室1/4圆喷嘴 Quadrant nozzle with carrier-rings
  蜗轮流量变送器 Turbine flow transmitter
  频率转换积算器 Frequency transducer with integrator
  三阀体 Three-valve manifold
  三通电磁阀 Three-way solenoid valve
  小口径旋翼式冷水水表 Rotating vane type cold water-meter
  TYQ-2型外浮筒液面调节器 Type TYQ-2 external cage displacer level controller
  QBF3型单插入式法兰差压变送器 Type QBF3 single insertion flanged differential pressure transimitter
  带平面(或槽面,凹面)密封面的节流装置 Throttling device with flat (or grooved, female) sealing surface
  法兰上钻孔取压的节流装置 Throttling device with drilled holes on flange
  带槽面(或凹面)环室取压的节流装置 Throttling device grooved (or female) carrier-ring
  圆形均压环取压的孔板 Orifice plate with circular pressure-equalizing rings
