弹簧管压力表 Burdon-tube manometer
氨用压力表 Ammonia manometer
氨用电接点压力表 Ammonia manometer with electric contacts
隔膜压力表 Diaphragm sealed manometer
法兰膜片隔离式压力表 Flanged diaphragm sealed manometer
标准压力表 Standard pressure gauge
电接点弹簧压力表 Bourdon-tube manometer with electric contacts
氨用真空表 Ammonia vacuum-gauge
膜片真空表 Membrane vacuum-gauge
风压表 Output air pressure gauge
膜盒式微压计 Capsule-type micromanometer
双波纹管差压计 Differential pressure gauge with double bellows
活塞式压力计 Piston type pressure gauge
补偿微压计 Compensating micromanometer
带冷凝管压力表 Manometer with condensing tube
