您的位置:控制工程论坛网论坛 » 传感器 » smiq03矢量信号源
pygyiqi
pygyiqi   |   当前状态:离线
总积分:147  2025年可用积分:0
最后登录时间: 2008-12-18
smiq03矢量信号源
pygyiqi  发表于 2008/11/13 14:28:16      916 查看 0 回复  [上一主题]  [下一主题]
Rohde SMIQ03 Measurements/Features
Wireless comp Design & Test
Manufacturing Test
Mobile Phone Design and Test
Base Station Design & Test
Dig Video Comp & System Design
Wideband CDMA Development
Univesal modulation coder
Fading simulator
Rohde SMIQ03 Performance Characteristics
Form Factor
Benchtop
Minimum Frequency
300 kHz
Maximum Frequency
3.3 GHz
Frequency Resolution
0.1 Hz
Frequency Switching Time
15 ms
Time base stability
0.000001 /yr
External Frequency Reference
16 MHz
Minimum Output Power
-140 dBm
Maximum Output Power
13 dBm
Power Resolution
0.1 dB
Output Impedance
50 Ohm
Minimum Single-Side-Band Noise
-135 dBc/Hz
Maximum Single-Side-Band Noise
-130 dBc/Hz
Harmonics (noise)
-30 dBc
Non-harmonics (noise)
-60 dBc
Modulation
AM,FM,Pulse
External Modulation Inputs(Types)
Yes
Sweep Modes
Linear,List,Log
Rohde SMIQ03 Programmability/Connectivity
User Interface
Proprietary
Ports to Peripheral Devices
IEEE488
Test Pattern Storage
50 Patterns
Programming Language
SCPI
Rohde SMIQ03 Life Cycle Data
Out of Production
Nov-01-2000
Rohde SMIQ03 Compliance
CE Compliance
Not on file
UL Compliance
Not compliant
Rohde SMIQ03 Power Requirements
Input Power
Universal (Auto Sense and Switch)
Rohde SMIQ03 Physical Dimensions
Width
435 mm(17.12 in)
Height
192 mm(7.55 in)
Length
460 mm(18.11 in)
Weight
25 kg(55.11 lb)
