您的位置:控制工程论坛网论坛 » 产品供求 » DELIKON metallic liquid tight connector,liquid tig
semi
semi   |   当前状态:在线
总积分:266  2025年可用积分:0
最后登录时间: 2013-11-06
semi  发表于 2009/1/4 11:36:28      663 查看 0 回复  [上一主题]  [下一主题]
Delikon braided flexible metal conduit for airport terminal wirings
Over Braided Flexible Conduit,Liquid Tight Conduit and Fittings For Demanding Projects
Flexible metallic overbraided systems from delikon provide the best solution for the most demanding applications.
Originally developed for use on machining and OEM applications, Delikon protective overbraided flexible steel conduit systems have continuously evolved to included specialised systems for chemical, engineering, offshore, rail, underground, tunnel and security applications. They are available in a wide selection of nominal conduit diameters up to 4 inches to best meet individual application requirements.
Delikon overbraided flexible conduit systems protect vulnerable cabling on metal machining, welding or heavy plant where abrasion, spillage and increased temperature are all serious operational considerations. They also satisfy arduous demands on railway rolling stock and on essential trackside applications, such as signalling and communications
In its various forms and with earth continuity via the system s fittings, the overbraiding can afford a standard, enhanced or high degree of EMI screening capability, protecting the cables carried within the flexible system.
All overbraided flexible conduit systems provide an inherent low fire hazard installation or where electromagnetic interference EMI screening of conduit is required.
Delikon overbraided flexible conduit systems also offer cost-effective alternatives to individually screened cables within applications where cross talk has no adverse effect. Additionally, the user gains the mechanical advantage of a cable management system, which affords the means to easily add, substitute or replace cables in an existing cable run at any time.
http://www.delikon.com
http://users6.nofeehost.com/delikon20/
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/cbraidst.jpg" alt="overbraided flexible steel conduit systems">
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/airpot2.jpg" alt="Over Braided Flexible Conduit, Liquid Tight Conduit and Fittings For Demanding Projects">
