您的位置:控制工程论坛网论坛 » 产品供求 » Liquidtight flexible metallic conduit with filler
semi
semi   |   当前状态:在线
总积分:266  2025年可用积分:0
最后登录时间: 2013-11-06
semi  发表于 2009/1/4 11:37:36      533 查看 0 回复  [上一主题]  [下一主题]
Liquidtight flexible metallic conduit with filler and fittings,sealtite conduit
electric liquidtight flexible metal conduit for transformer wirings
Liquid-tight Conduit with smooth PVC jacket
Aluminum liquidtight connectors for flexible conduits
Liquatite Flexible Metal Conduit
Flexible Metal Conduit, Liquid-tight
Electric liquidtight flexible metallic conduit,connector,fittings
electric Liquid Tight Flexible metal Conduit,LT metal conduit
Liquidtight conduit and connector
Liquidtight Flexible metal Conduit,connectors
Liquid Tight Flexible PVC Coated metal Conduit
Color Liquid-Tight Connectors
for more professional cable managements.
Machine grey LIQUIDTIGHT Flexible metal conduit
Liquidtight Flexible steel Conduits and NEW ALUMINUM connectors
LiquidTight Flexible Metal Conduit LFMC CONDUITs
( Protecting wiring in wet locations )
Liquid-tight conduit is ideal when used with liquid-tight fittings for applications where a high degree of liquid tightness is required.  This product is suitable for a number of general purpose wiring applications and ideal for environments with lots of water, coolant, and vibrations such as machine tool workshops.
Superior quality Aluminum Liquid-tight Connector for liquid tight conduit
 This new line of connectors are made of high-quality forged aluminum for superior strength and durability. These unique configurations work perfectly with our whole range of flexible conduits and hoses. All forged connectors feature:
* All aluminum construction
* Totally re-useable
* Unique taper design for simple assembly and superior water tightness.
* Fixed or swivel type.
http://www.delikon.com
http://users4.nofeehost.com/delikon
Flexible, sleek, with increased IP ratings, Liquid-tight flexible metallic conduit (LFMC) is suitable for use in a variety of environments and applications from general purpose wiring in wet or damp locations, to direct burial and in concrete embedment, to raised computer room floors and site lighting jobs.
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/liquid6.jpg" alt="Electric liquidtight flexible metallic conduits">
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/greysys.jpg" alt="Electric liquidtight flexible metallic conduits">
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/YF-706.gif" alt="Electric liquidtight flexible metallic conduits">
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/al-cat.gif" alt="Aluminum Liquid-tight Connectors">
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/ancon2.jpg" alt="Aluminum Liquid-tight Connectors">
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/lt3.jpg" alt="Aluminum Liquid-tight Connectors">
<p align="center"><a href="http://www.delikon.com/braids.htm"><img border="0" src="http://www.delikon.com/images/ship1.jpg" alt="For Ship building">
<p align="center"><a href="http://www.delikon.com/greyliq.html"><img border="0" src="http://www.delikon.com/images/grey706l.jpg" alt="metal liquid tight conduit">
DELIKON metallic liquid tight connector,liquid tight connector and fittings SEALtite metal connector
liquid tight connector,LT connector,LT fittings
conector recto hermetico,curvo 90
Liquid-tight zinc die cast connectors
Model: DMA,DMB
Available in 3/8 inch to 4 inch trade size
Zinc Die-cast construction
For use with both Metallic Liquid tight Conduit and Nonmetallic Liquid tight Type B
Resistant to outdoor weather conditions
Liquidtight/Raintight/OilTight
Suitable for wet locations
Suitable for grounding (through 1-1/4")
Locknut included
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/dmb.gif" alt="Liquid-tight zinc die cast connectors">
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/liqcon1.jpg" alt="Liquid-tight connectors">
Computer Blue Liquid-tight Flexible steel Conduit
( YF-604 )
Computer Blue is a liquid-tight flexible steel conduit commonly used for computer room installations. The blue jacket color easily identifies circuitry for computer power wiring. It has a flexible inner core made from a spiral wound strip of heavy gauge, electro-galvanized steel. It contains an integral copper bonding wire.
Applications:
Liquid-tight flexible conduit provides protection for wiring circuits located in extremely wet or damp areas. This computer BLUE is especially suitable for wirings in computer rooms.
This conduit is intended for:
    -For use in exposed or concealed locations.
    -Installations under raised floors in Data Processing Areas.
    -Direct burial and in poured concrete.
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/blue-1.gif" alt="Liquidtight flexible steel conduit">
