您的位置:控制工程论坛网论坛 » 产品供求 » Braided Flexible metal conduit with stainless stee
semi
semi   |   当前状态:在线
总积分:266  2025年可用积分:0
最后登录时间: 2013-11-06
semi  发表于 2009/1/4 11:37:58      672 查看 0 回复  [上一主题]  [下一主题]
Braided Flexible metal conduit with stainless steel braiding for heavy mechanical stress
With additional stainless steel wire braiding, flexible Metal conduit with stainless steel braiding is used to counter mechanical stress and is highly flexible, though resistant against tensile stresses and transverse.
Braided Flexible Metallic Conduits
DELIKON overbraided flexible metal conduit systems protect vulnerable cabling on metal machining, welding or heavy plant where abrasion, spillage and increased temperature are all serious operational considerations.
EMC Shielding for CNC machine toolings and automation wirings
The Screen System overbraiding can afford a standard or high degree of EMI screening capability protecting the cables carried within the flexible system.
<p align="center"><a href="http://www.delikon.com/cncwire.htm"><img border="0" src="http://www.delikon.com/images/cncwirel1.jpg" alt="Braided Flexible metal conduit with stainless steel braiding for heavy mechanical stress">
http://users6.nofeehost.com/delikon20/
