您的位置:控制工程论坛网论坛 » 电力自动化社区 » 供配电系统
liangdunfei168
liangdunfei168   |   当前状态:离线
总积分:258  2025年可用积分:0
最后登录时间: 2009-07-29
供配电系统
liangdunfei168  发表于 2009/2/15 0:20:21      1289 查看 1 回复  [上一主题]  [下一主题]
  • Doncloud
    Doncloud   |   当前状态:离线
    总积分:87  2025年可用积分:0
    最后登录时间: 2009-03-23
    Doncloud   发表于 2009/2/15 0:20:21
    A Butterfly Valve (蝶阀)is from a family of valves called quarter turn valves. The "butterfly" is a metal disc mounted on a rod. When the valve is closed, the disc is turned so that it completely blocks off the passageway. When the valve is open, the disc is rotated a quarter turn so that it allows unrestricted passage. The position of the disc is effected from outside the valve.
    Globe Valve, Solenoid Valve, Ball Valve, Check Valve, Plug Valve
    Tantex Corporation, 欢迎选购。
    引用 Doncloud 2009/2/15 0:20:21 发表于2楼的内容
