您的位置:控制工程论坛网论坛 » 产品供求 » 标量网络分析仪AC/DC同轴检波器 Agilent 85025A
bfsy17
bfsy17   |   当前状态:离线
总积分:282  2025年可用积分:0
最后登录时间: 2012-06-12
bfsy17  发表于 2009/2/11 17:39:54      704 查看 0 回复  [上一主题]  [下一主题]
010-62123259  孙廷孝 QQ:52634729
www.buy17.com  www.sy-yq.com
现货供应扫频仪 特价
名 称:四端口连接器 Four-Port Junction Pad
型 号:MP659A
厂 家:日本安立 Anritsu
40 to 1000MHz, 1瓦, 50欧
MP659A 可用作一个阻抗匹配盒并应用在混合输出三个射频数字调制信号源到一个接收机输入终端头以测量三个讯讯号特性( 如接收机 SINAD 表现)
标量网络分析仪 8757D AC/DC检波器 现货特价
Agilent/hp 85025A
AC/DC检波 频率:10M - 18G
传输/反射测量装置 HP 8502A
The 8502A (50n),Transmission/Reflection Test Set contains a power splitter and directional bridge allowing transmission and reflection measurements using the same test setup. It also incorporates a 0 to 70 dB, 10 dB step attenuator to reduce the incident signal level without affecting the signal level at the R input.
Frequency Range: 500 kHz - 1.3 GHz (2.6 GHz w/ option H26)
Impedance 50 Ohms
Directivity: >40 dB
Frequency Response:
Magnitude: < 0.8 dB
Phase: < +8 degree
Reflection:
Magnitude: < +1.5dB from 0.5 to 1.3 GHz
Phase: < +/- 15 degree from 0.5 to 1.3 GHz
8756与8757系列网络分析仪 AC检波器 hp 11664D
Scalar detector, 26.5-40 GHz
AC mode only
Dynamic Range: +10 to -50dBm
Return loss: 12dB
Frequency Responce: +/-1.5dB
Dynamic Range: +/-0.5dB
Low-Barrier Schottky Diode Detector
型号: HP 8470B
频率10 MHz-18 GHz
频率响应: ±0.3 dB to 12.4 GHz, ±0.5 dB to 15 GHz, ±0.6 dB to .18 GHz
Frequency response: 1.15 to 4 GHz, 1.3 to 18 GHz)
Low-level sensitivity: > 0.5 mV/uW
Maximum operating input power: 200 mW
Typical short-term maximum input power (< 1 minute): 1 W
Noise: < 50 uV
Output polarity: negative
Input connector: APC-7
MARCONI Wide Band Detector 检波器
型号: 6163 ? 50 ohms
频率: 0.05 -18GHz
Input "N"  (Male)/Output "BNC"
