您的位置:控制工程论坛网论坛 » 产品供求 » 蝶阀, 对夹式蝶阀, Wafer Butterfly Valve
Doncloud
Doncloud   |   当前状态:离线
总积分:87  2025年可用积分:0
最后登录时间: 2009-03-23
Doncloud  发表于 2009/2/15 0:10:30      1170 查看 0 回复  [上一主题]  [下一主题]
A Butterfly Valve (蝶阀)is from a family of valves called quarter turn valves. The "butterfly" is a metal disc mounted on a rod. When the valve is closed, the disc is turned so that it completely blocks off the passageway. When the valve is open, the disc is rotated a quarter turn so that it allows unrestricted passage. The position of the disc is effected from outside the valve.
Globe Valve, Solenoid Valve, Ball Valve, Check Valve, Plug Valve
Tantex Corporation, 欢迎选购。
