您的位置:控制工程论坛网论坛 » 产品供求 » DELIKON flexible conduit
semi
semi   |   当前状态:在线
总积分:266  2025年可用积分:0
最后登录时间: 2013-11-06
semi  发表于 2009/3/13 22:00:44      596 查看 0 回复  [上一主题]  [下一主题]
flexible conduit,liquidtight,flexible metal condui,metallic,braided flexible conduit,hose,fittings,electrical ducting,liquid-tight connector,stainless steel,corrugated nylon,Delikon,FMC,LFMC,LFNC,cable management,wiring harness,sleeving,wiring accessories,explosion proof,EMT fittings,PTFE Teflon,Stainless Steel Wire Over-Braided Flexible Hose,EMI shielding conduit,Corrugated Stainless Steel Hose,automotive hose,AN hose,race car performance hose,plumbing,rubber hose,pliable,LIQUID TIGHT galvanized steel conduit,flexible conduit assembly,liquidtight flexible galvanized steel conduit,LIQUID TIGHT CONDUIT,raceway,tube,small bore,pvc jacketed,covered
electrical Flexible conduit or connector for industrial cable management
Delikon cable protection metal hoses,
perfect all-round protection for cables and lines.
Electrical flexible conduit,connector,Liquidtight conduit
Flexible metal conduit and fittings for wiring harness
Shanghai Delikon Tubing Co., Ltd. electric flexible liquidtight metal conduit,fittings
Delikon flexible conduits & fittings ---
Your Professional Electrical Wiring Protection Solutions.
Delikon, a leading Chinese manufacturer and exporter for electrical flexible conduits, fittings, high performance braided race car hose, and flexible ducting for various applications, our business philosophy has always been based on quality products, innovative solutions, and service beyond our customers expectations. We highly
appreciate your business and hope that you find a flexible solution for your projects from our informative and efficient website .
We manufacture and export an extensive range of metallic and non-metallic electrical flexible conduits and fittings for a variety of installations requiring motion, vibration and bending.  They offer good mechanical and moisture protection to enclosed conductors.
Products & Services:
   *Metal Wire over-braided Flexible Conduit
     (EMI shielding. EXplosion proof! Suitable for use in industrial Location)
   *Liquid-tight Flexible Conduit and Fittings
   *Flexible Metallic Conduit (FMC) (Square-locked, interlocked)
   *Flexible Non-metallic Conduit
   *Flexible Conduit Connectors & Fittings
   *Teflon (PTFE) Flexible Hose, With Metal Wire Over-braiding
   *Corrugated Stainless Steel Hose
   *EMT Conduit Fittings
   *OEM, Manufacturing as per customers samples & specifications
Applications: - For electrical wiring protections & managements where flexibility is necessary for installation, maintenance or where vibration and movement must be absorbed. Our electrical products are used in construction, industrial facilities, wire harnesses, machine tools, instrumentation and telecom equipments.
Flexible Hose For Automobiles (AN hose, hose end, engine hose, fuel rubber hose), OEM Products, Flexible hose, tubing, ducting and fittings for exhaust, fluid & gas handling and other applications are also available. Please write to us for more details.)
Main Customers:
OEMs, electrical contractors, machineries manufacturers, ships & trains builders, automobiles manufacturers, electrical wholesale distributors, and importers. We also sell our products to manufacturers of wire harnesses, wire assemblies, and producer of electrical appliances.
OEM Service:
Manufacturing as per customers samples & specifications. Send us your requirements and we will come up with a solution for you.
http://www.delikon.com
http://www.semiconduits.com
http://users4.nofeehost.com/delikon
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/ex.jpg" alt="Electric flexible conduits">
Flexible Conduits For Wiring Harness
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/harness2.jpg" alt="flexible conduit for wiring harness">
flexible conduits systems for ship building electrical wrings:
<p align="center"><a href="http://www.delikon.com/search.htm"><img border="0" src="http://www.delikon.com/images/ship1.jpg" alt="ship building electrical wrings">
