您的位置:控制工程论坛网论坛 » 产品供求 » BRAIDED LIQUIDTIGHT STEEL CONDUIT
semi
semi   |   当前状态:在线
总积分:266  2025年可用积分:0
最后登录时间: 2013-11-06
semi  发表于 2009/3/13 22:05:56      672 查看 0 回复  [上一主题]  [下一主题]
high strength metal overbraided flexible liquidtight metal conduit
Overbraided metallic LiquidTight conduit with stainless steel braid is suitable for industry environments wirings protections.
Overbraided LiquidTight metal conduit with steel Braid for contruction machine wirings
Galvanised flexible Steel Conduit, Smooth PVC Covering, Metal Overbraid
Braided Liquidtight Flexible EMC Shielded metal Conduit
EMI/RFI Shielding electrical Flexible Conduit,Liquid-tight
Model: YF-705
This conduit is designed to protect sensitive electronic circuits in applications such as communications, radar and data transmission from Electro-Magnetic and Radio Frequency Interference (EMI / RFI). Most suitable for radar equipments, airports, CNC machineries and PLC wirings in industrial environments.
*Wire over-braiding provides more abrasion resistant, EMI shielding and resistance to hot metal splashes.
*Explosion proof. Liquid-tight.
*Durable and long life.
*High tensile strength.
*Inner core made from  galvanized steel strip.
*Square locked construction with packing for more tensile strength or air tightness.
*Other packing materials: copper bonding (grounding) wire, PVC wire packing is also available.
http://www.delikon.com
http://www.semiconduits.com
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/YF-705.gif" alt="EMI/RFI Shielding">
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/cbraidst.jpg" alt="braided flexible steel conduits">
