您的位置:控制工程论坛网论坛 » 产品供求 » Braided Flexible Steel Conduit,Aluminum Connector
semi
semi   |   当前状态:在线
总积分:266  2025年可用积分:0
最后登录时间: 2013-11-06
semi  发表于 2009/3/23 14:44:13      596 查看 0 回复  [上一主题]  [下一主题]
over-Braided Flexible Steel Conduit,Aluminum Connector for metal works cables protection
Over Braided Flexible Conduit system specially designed for cables protections in steel mills, glass works and electric furnaces, resists hot metal splashes.
MODEL: SM-70001
Overbraided Flexible Steel Conduit For High Temperature Wiring
Inherently low fire hazard (ILFH),  Braided Flexible Metal Conduit is widely used to counter mechanical stress and is highly flexible, and it is resistant against tensile stresses and transverse pressure. This conduit also offers excellent protection to cables against hot metal particles, and immunity from electromagnetic interference. Most suitable for use in Hazardous Locations, industrial environments and high temperatures.
MODEL: YF-704
Clean data transmission in a noisy environment is an ever increasing requirement on todays crowded factory floors. Braided flexible steel conduit systems provide excellent EMI and RFI shielding, as well as mechanical protection, resulting in improved data transmission for factory automations.
http://www.delikon.com
http://users4.nofeehost.com/delikon
<p align="center"><a href="http://www.delikon.com/smill.htm"><img border="0" src="http://www.delikon.com/images/ironml1.jpg" alt="Braided Flexible Steel Conduit,Aluminum Connector for steel mill cables protection">
