您的位置:控制工程论坛网论坛 » 产品供求 » 新到HP 4140B皮可安培计/直流电压源
bfsy17
bfsy17   |   当前状态:离线
总积分:282  2025年可用积分:0
最后登录时间: 2012-06-12
bfsy17  发表于 2009/5/13 14:22:43      1631 查看 1 回复  [上一主题]  [下一主题]
pA表/直流电压源 HP 4140B
厂家:Agilent/HP
  • 三种基本的半导体测量:I,I-V和准静态的C-V
  • 可编程电压源:±100V可编程源/函数发生器,±100V可编程直流电压源
  • 基本精度:0.5%
  • 高分辨率:1fA
  • 准静态C-V:0.1~1999pF,dc电压斜率1mV/s~1V/s,增量为1mV/s
Agilent 4140B pA表/直流电压源是测量仪器的组成部分,它由一个非常稳定的微微安表和两个可编程直流电源组成,其中一个用作斜坡和阶梯波发生器的操作和直流电源。这些特点使得4140B成为直流特性测量,如漏电流,电流电压特性,准静态C-V测量的理想工具,以满足半导体工业发展新产品和提高产量的要求。在测量电子部件和材料确定漏电流或绝缘电阻时它是有用的。
4140B也可用于半导体器件的开发,生产和质量控制,改善电子元件和设备的可靠性。
HP/Agilent 4140B pA Meter/DC Voltage Source Features:
  • 3 basic semiconductor measurements: I, I-V and quasi-static C-V
  • Two programmable voltage sources
  • High resolution: 0.001 x 10-12 A
  • HP-IB standard
Component Measurement instrumentation. It consists of an extremely stable picoampere meter and two programmable dc voltage sources, one of which operates as a ramp and staircase generator as well as a dc source.
  • Stable pA Measurements
    * maximum resolution of 10-15 A
    * low noise test leads, and an electrostatic and light shielded test fixture
  • Synchronized I-V Measurements
    * precise, programmable timing capability, we can now make fast, accurate I-V and C-V measurements
  • Quasi-Static C-V Measurements
    * automatic quasi-static C-V measurements are easily accomplished by the ramp voltage capability
  • HP-IB Capability
Specifications:
  • Measurement Functions: I, I-V and C-V
  • Voltage Sources: two separate sources (VA and VB)
  • VA: ± 100V programmable source/function generator
  • VB: ± 100V programmable dc voltage source
Measurement Function/Source Selection
  • Function: I, I-V, C-V
  • Voltage sweep: auto or manual (pause)
Current Measurements
  • Displays: current, 3? digits with 2 character annunciator. Voltage, 3? digits
  • Measurement range: ±0.001 x 10-12 A to 1.000 x 10-2 A full scale in 11 ranges
  • Overrange capability: 99.9% on all ranges
  • Range selection: auto (lowest current range is selectable) and manual
  • Zero Offset: cancels leakage current of test leads or test fixtures
  • Offset range: 0 to ± 100 x 10-15 A
  • Trigger: INT, EXT and HOLD/MAN
  • Input terminal: triaxial
Capacitance-Voltage (C-V) Measurement
  • Measurement ranges: 0.0 pF - 100.0 pF and 200 pF - 1000 pF full scale in two ranges; 99.9% overrange
  • Ranging: auto
  • % C: capacitance change of device under test is displayed as a percent of the set value of the oxide capacitance (Cox = 100%)
  • %C range: 0.0% - 199.9%
  • Cox setting ranges (2 ranges): 0.1 pF - 199.9 pF and 200 pF - 1999 pF
  • Zero offset: cancels stray capacitance of test fixtures and test leads
  • Offset range: 0 to 100 pF
  • High speed I data output: available with HP-IB interface only. Outputs current measurement data at 4 ms intervals (max rate)
DC Voltage Sources
  • Output Modes, VA and VB
  • VA: Ramp up, Ramp up/down, Staircase up, Staircase up/down, dc
  • VB: dc
  • Voltage ranges (VA and VB): 0 to ± 10.00V and 0 to ± 100.0V in 2 ranges, auto range only
  • Maximum current: 10 mA, both sources
  • Voltage sweep: auto and manual (pause), up/down step in manual (pause) mode. Sweep abort standard
Operating Parameter Setting Ranges
  • Start voltage and stop voltage: 0 - ± 10.00V, 0.01V steps; 0 - ± 100.0V, 0.1V steps
  • Step voltage: 0 - ± 10.00V, 0.01V steps; 0 - ± 100.0V, 0.1V steps
  • Hold time: 0 - 199.9 seconds in 0.1s increments; 0 - 1999 seconds in 1.0s increments
  • Step delay time: 0 - 10.00 seconds in 0.01s increments; 0 - 100.0 seconds in 0.1 increments
  • Ramp rate (dV/dt): 0.001 V/s - 1.000 V/s in 0.001 V/s increments
Current Measurement
  • Range: 10-2 - 10-8, 10-9, 10-10, 10-11, 10-12
Analog Output I, C and VA
  • Low pass filter: 3 position: OFF, 0.22s ± 20% and 1s ± 20% applied to both VA and I/C data outputs
  • Pen lift output
  • Recorder output scaling: push button scaling of lower left and upper right limits of X-Y recorder
  • zhugejian
    zhugejian   |   当前状态:在线
    总积分:55  2025年可用积分:0
    最后登录时间: 2011-09-08
    zhugejian   发表于 2011/9/8 21:33:35
    你好,请问控制这台仪器的驱动程序是什么?
    引用 zhugejian 2011/9/8 21:33:35 发表于2楼的内容
