您的位置:控制工程论坛网论坛 » 嵌入式系统 » PIC单片机实现CRC的小程序
mcumao
mcumao   |   当前状态:离线
总积分:1503  2025年可用积分:0
最后登录时间: 2007-06-11
PIC单片机实现CRC的小程序
mcumao  发表于 2006/8/24 1:10:34      896 查看 0 回复  [上一主题]  [下一主题]
PIC单片机实现Dallas的iButton通讯时,编了段产生和校验CRC的子程序。
    #include <P16CE625.INC>
    cblock    0x20
datBuff:8            ;assign 8 byte data buffer
bit_cnt                ;bit counting
CRC_COUNT            ;number of bytes for CRC
CRC_RESULT            ;CRC resulr
crc_temp            ;temporary data buffer during CRC
    endc
#define    skp0    btfsc
#define    skp1    btfss
    org    0x000
    movlw    .7
    movwf    CRC_COUNT
    movlw    datBuff
    movwf    FSR        ;FSR point to data buffer
    call    CRC_CHECK
    movwf    datBuff+7
    goto    $
;CHECK THE CRC FOR ? BYTES DATA
;For the polynomial of X^8 + X^5 + X^4 + 1
;Derived from Dallas's iButton standard
;Before calling, FSR       = data buffer
;                CRC_COUNT = number of bytes for CRC
CRC_CHECK    ;~~~~~~~~~~~~~~~
    clrf    CRC_RESULT    ;initialize the CRC buffer
_crc_00
    movlw    .8        ;number of bits for one byte
    movwf    bit_cnt        ;set bit counter
    movf    INDF,w        ;get one data byte
    movwf    crc_temp    ;copy to temporary location
_crc_01
    rrf    crc_temp,f    ;get LSB in C
    skpc            ;is this LSB=1?
    goto    _crc_02        ;go if LSB=0
    movlw    0x01        ;do if LSB=1
    xorwf    CRC_RESULT,f
_crc_02
    rrf    CRC_RESULT,w    ;get LSB of CRC
    skpc            ;test LSB
    goto    _crc_03        ;go if LSB=0
    movlw    0x18        ;do if LSB=1
    xorwf    CRC_RESULT,f    ;polynomial implementation
_crc_03
    rrf    CRC_RESULT,w    ;whole byte right rotate
    rrf    CRC_RESULT,f
    decfsz    bit_cnt,f    ;bit counting
    goto    _crc_01        ;go on until aa 8 bits done
    incf    FSR,f        ;pointer update to next byte
    decfsz    CRC_COUNT,f    ;byte counting
    goto    _crc_00        ;go on until all byte done
    movf    CRC_RESULT,w    ;get CRC, Z set if CRC=0
    return            ;return with CRC in W
    END
