您的位置:控制工程论坛网论坛 » 嵌入式系统 » 研华新产品
birdoo_ivy
birdoo_ivy   |   当前状态:离线
总积分:493  2025年可用积分:0
最后登录时间: 2009-03-20
研华新产品
birdoo_ivy  发表于 2006/8/25 10:08:59      1521 查看 0 回复  [上一主题]  [下一主题]
PCA-6190
LGA 775 Pentium® 4/Celeron® D Processor Card with VGA/Dual GibE LAN/DVI
主要特点:
· Intel® 915 GV (Grantsdale-GV) chipset 533/800 MHz FSB
· Supports Dual Channel DDR2 400/533 SDRAM
· Supports up to 4 Serial-ATA devices
· 8 USB 2.0 ports
· 2 PCI-Express x1 for LAN chip
· Supports DVI interface (PCA-6190G2-D0A1 only)
· 14-pin General Purpose I/O interface as 8-bit programmable Digital I/O or port80 function
· CMOS automatic backup and restore to prevent accidental data loss of BIOS setup
PCA-6289
Socket 604 Dual Xeon TM/LV Xeon TM Processor Card with VGA/Dual Gigabit LAN/HISA (533 MHz FSB)
主要特点:
· Support single/dual socket 604 Intel® Xeon®/LV Xeon processors up to 3.2 GHz
· Dual Channel DDR 200/266 SDRAM up to 8 GB
· Intel® E7501 chipset 400/533 MHz FSB
· Onboard ATI Rage XL with 8 MB frame buffer memory
· 64-bit, 66MHz PCI-X
· Supports 10/100/1000Base-T Ethernet
· 4 USB 1.1 ports
· Low-profile customized CPU cooler included
AIMB-762
LGA 775 Pentium® D/Pentium® 4/Celeron® D Processor-based Industrial ATX Motherboard with DDR2/PCI-Express/Dual Gigabit LAN (533/800 MHz FSB)
主要特点:
· Intel® 945G chipset 800 MHz FSB
· Dual channel DDR2 533/667 SDRAM up to 4 GB
· Chipset integrated VGA sharing 224 MB system memory
· PCI-Express x16 slot for VGA card
· Four SATA II ports with 300 MB transfer rate and (software RAID 0, 1, 10, 5)
· Supports dual 10/100/1000Base-T Ethernet via dedicated PCIe x 1 bus
· Compatible with Advantech's 2U, 4U, 5U and 7U Chassis
ACP-4362MB
4U-High Rackmount Chassis with 6 SATA HDD Trays for RAID System
主要特点:
· Supports up to six SATA II or SATA I HDDs which can be used for RAID application
· Supports either motherboard or 14-slot backplane
· Supports one slim-type CD-ROM drive and one 3.5” FDD or HDD
· LED indicators and alarm notification for system fault detection
· Front-accessible USB and PS/2 I/O connectors
· Lockable front door prevents from unauthorized access
· Easy-replaceable 84 CFM cooling fan with air filter and two 47 CFM fans for SATA storage devices
· Versatile PS/2 and redundant power supply options
DVS-350
DVS-350提供了在数字视频市场领域中完美的解决方案,它能更好的适应苛刻环境中的应用,尤其在巴士、轨道交通、公共安全的特种车辆(警车、危险品运输车辆等)方面提供了最佳的视频监控解决方案。DVS-350是目前最小的工业级PC-based系统,它通过4块Conexant878A芯片,系统最高可支持16路视频输入,由于针对移动环境进行了特殊设计,使得整个系统更易于操作和整合。此外,X86开放式平台更易于应用软件二次开发和整合应用,例如电子地图、GPS全球定位系统、数字记录器等设备应用于DVS-350。DVS-350外观设计独特紧凑,最大的安装高度仅为69mm,它可以抵抗最高达20G的冲击,并且可以承受高达1G的抗振动性。基于无风扇、抗震动、抗冲击的优良设计,使其可安装运行在任何关键任务的环境中。宽电压(9-30VDC)能更好的保护在车载应用中的电涌冲击。整合了TV-OUT、WLAN、单独的DI和Relay DO特性使得DVS-350成为嵌入式/移动式应用中最佳的解决方案。研华科技将其定位于满足各种应用的数字视频平台,并提供可选购的视频监控软件。综上所述,结合DVS-350的X86平台的优良扩展性,使其成为具有多视频通道监控和优秀图像质量以及可选的软件模块的最佳视频监控平台。
