您的位置:控制工程论坛网论坛 » 嵌入式系统 » 嵌入式Linux内核优化裁剪
zhiy66
zhiy66   |   当前状态:在线
总积分:6528  2025年可用积分:0
最后登录时间: 2012-01-11
嵌入式Linux内核优化裁剪
zhiy66  发表于 2009/7/6 16:43:06      681 查看 0 回复  [上一主题]  [下一主题]
优化1、取消虚拟内存的支持
General setup  --->
     [ ] Support for paging of anonymous memory (swap)
 优化2、使用默认的IO调度器,取消其他的调度器
-*- Enable the block layer  --->
      IO Schedulers  --->
  < > Anticipatory I/O scheduler
  <*> Deadline I/O scheduler
  < > CFQ I/O scheduler
  Default I/O scheduler (Deadline)  --->
 优化3、取消对旧版本二进制执行文件的支持
Userspace binary formats  --->
 < > Kernel support for a.out and ECOFF binaries
 优化4、取消不必要的设备的支持
Device Drivers  --->
 <*> Memory Technology Device (MTD) support  --->
  [*]   MTD partitioning support
  < >     RedBoot partition table parsing
    RAM/ROM/Flash chip drivers  --->
   < > Detect flash chips by Common Flash InteRFace (CFI) probe
   < > Detect non-CFI AMD/JEDEC-compatible flash chips
   < > Support for RAM chips in bus mapping
   < > Support for ROM chips in bus mapping
   < > Support for absent chips in bus mapping
 < > Parallel port support  --->
 [ ] Block devices  --->
 < > ATA/ATAPI/MFM/RLL support  --->
   Input device support  --->
  [*]   Keyboards  --->
   < >   AT keyboard
  Character devices  --->
  [ ] Non-standard serial port support
    Serial drivers  --->
   < > 8250/16550 and compatible serial support
       *** Non-8250 serial port support ***
   <*> Samsung S3C2410/S3C2440/S3C2442/S3C2412 Serial port support
   [*]   Support for console on S3C2410 serial port
  [ ] Legacy (BSD) PTY support
   SPI support  --->
  [ ] SPI support
 < > Hardware Monitoring support  --->
 优化5、取消不需要的文件系统的支持
File systems  --->
  < > Second extended fs support
  < > Ext3 journalling file system support
  < > Ext4dev/ext4 extended fs support development (EXPERIMENTAL)
   Miscellaneous filesystems  --->
   < > Journalling Flash File System v2 (JFFS2) support
完成以上的优化配置有,内核镜像会由之前的1.9MB缩减到1.7MB左右。
