您的位置:控制工程论坛网论坛 » 产品供求 » small bore flexible Stainless Steel Conduit
semi
semi   |   当前状态:在线
总积分:266  2025年可用积分:0
最后登录时间: 2013-11-06
semi  发表于 2009/7/20 15:37:23      539 查看 0 回复  [上一主题]  [下一主题]
small bore flexible Stainless Steel Conduit for chemical sensors wirings
Flexible stainless steel conduit for electric wirings protections
Strip wound small ID flexible metallic conduit,hose for electrical wirings armoring
braided Small BORE Flexible stainless steel conduit,for automobile & industry wiring harness
Optical Fiber and sensors wirings protects Flexible metal conduit
Small bore Flexible metal conduit,for protection of instrument wirings
Small id Flexible Stainless Steel Conduit ( AT )
Small bore instrumentation tubing flexible conduit flexible stainless steel conduit for electric wirings
*Stainless steel strip (square locked or interlocked), very flexible *Corrosion Resistant
*EMI Shielding *Most suitable for instrument wiring protections.
MADE FROM STAINLESS STEEL STRIPS:
*ALL Stainless steel construction for corrosion resistant.
*Durable and long life.
*Designed for tight-spot installation and where continuous flexing is required
Applications:
Suitable for use in  Industrial environments. Protection for stainless tubes, sensor cords or electric cords. It is designed to protect sensitive electronic circuits in applications such as sensors, electronic instruments and industrial control wirings.
Flexible Stainless Steel Conduit: Type AT is an ultra-flexible, stainless steel conduit designed primarily for OEM applications. A typical application would be armouring in specialty sensing devices, or medical equipment, including fiber-optics.
SMALL BORE HOSE
Delikon manufactures unique tubing that is relied on in numerous industries. The tubing is produced by helical coiling of a cold-rolled metal strip onto a spindle, with the helical coils being linked with each other by means of a special type of strip profile. Basic materials for the strip are stainless steel or galvanized steel strip. However, other metals are also available.
Applications:
Instrumentation tubing is used by manufacturers of various industries, such as Process & Control Instrumentation, Measuring & Controlling Devices, Analytical Instruments, Medical Instruments and many others with specific applications including temperature measuring, wiring conduit or armor cable and protective casing.
Instrumentation tubing is made in two configurations, or constructions, commonly called SquareLok and InterLok, and is often abbreviated as SL and FI.
http://users4.nofeehost.com/delikon
