您的位置:控制工程论坛网论坛 » 产品供求 » 二手彩色信号发生器 K-7256 全制式电视机信号发生器(李生13005433157)
mtyq
mtyq   |   当前状态:离线
总积分:112  2026年可用积分:0
最后登录时间: 2011-08-28
mtyq  发表于 2009/8/23 17:51:44      704 查看 0 回复  [上一主题]  [下一主题]
HDCP, HDMI
250MHz Analog Video Pixel rate
DVI-I 165MHz digital output
NTSC, PAL, SECAM Composite and S-Video output
SCART
D-TV(TV) Signal output Capability : Y, Pb, Pr output
Audio R, L output
Built-in 100 Timing formats
Large custom memory : 300 Timing, 200 Pattern,
 200 Function group, 100 Scan group
2048X2048 graphic display size
All timing parameters are fully programmable
Power saving mode test capability
Easy and variable pattern edit function
RS-232C interface for PC Edit (WIN98, WIN2000) :
 Pattern, Timing, Scan, Function, System Program Download
ESD protection circuit
PIP : Analog & TV Signal output at the same time
Display Size2048X2048
Pixel Rate Range8MHz~250MHz / Error of less than 25ppm
Video LevelR, G, B (75 ohms) 0~1000mV programmable / 1 mV step
Sync on Green0.3VFix On/Off Support
Output connectorBNC, D-Sub 15-pin, DVI-I Analog
Protectionbuffered by 75-ohm isolation
