您的位置:控制工程论坛网论坛 » 现场总线 » 现场总线环境测试相关标准
hylotus
hylotus   |   当前状态:离线
总积分:5168  2025年可用积分:0
最后登录时间: 2012-08-16
现场总线环境测试相关标准
hylotus  发表于 2009/9/22 12:58:40      1156 查看 0 回复  [上一主题]  [下一主题]
现场总线环境测试相关标准
Ambient conditions
Extended temperature range from -40°C up to +70 °C, No fans
IP 20/IP30/IP67 Rel. Atmospheric humidity up to 95% (non-condensing).
Mechanical stability
Shock and vibration tests in accordance with
PLC standards IEC 1131-2, IEC 60068.
Electrical requirements
EMI: EN 50022, EN 50082-2, FCC part15 (class B) IEC 1000-4-2, IEC 1000-4-6, IEC 1000-4-4, EN 61000.
Certifications
CE, cUL60950, cUL 508 cUL 1604 Class1 Div (A,B,C,D) or FM 3611 Class 1
Div2 GL (Germanischer Lloyd) for maritime applications.
High MTBF values
(Mean Time Between Failure) CE, cUL60950, cUL 508 from approx.
20 to > 100 years, in comparison with office devices with typically 3 to 5 years.
