您的位置:控制工程论坛网论坛 » 站务交流 » 论坛的Bug: 论坛的搜索功能还是有问题
goldjack
goldjack   |   当前状态:在线
总积分:3142  2025年可用积分:0
最后登录时间: 2023-12-26
goldjack  发表于 2009/10/12 19:58:13      1144 查看 1 回复  [上一主题]  [下一主题]
网站首页的搜索功能是好的,但论坛里的搜索功能还是有问题。
错误如下:
Server Error in '/' Application.
The given key was not present in the dictionary.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[KeyNotFoundException: The given key was not present in the dictionary.]   System.ThrowHelper.ThrowKeyNotFoundException() +28   System.Collections.Generic.Dictionary`2.get_Item(TKey key) +7455996   Reed.WebSite.Web.Search.Controllers.SearchListController.Default(String q, String FuncName, Nullable`1 page) +797   lambda_method(ExecutionScope , ControllerBase , Object[] ) +182   System.Web.Mvc.ActionMethodDispatcher.Execute(ControllerBase controller, Object[] parameters) +17   System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) +178   System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +24   System.Web.Mvc.<>c__DisplayClassa.<InvokeActionMethodWithFilters>b__7() +53   System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) +258   System.Web.Mvc.<>c__DisplayClassc.<InvokeActionMethodWithFilters>b__9() +20   System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodWithFilters(ControllerContext controllerContext, IList`1 filters, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +193   System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) +382   System.Web.Mvc.Controller.ExecuteCore() +123   System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext) +23   System.Web.Mvc.ControllerBase.System.Web.Mvc.IController.Execute(RequestContext requestContext) +7   System.Web.Mvc.MvcHandler.ProcessRequest(HttpContextBase httpContext) +144   System.Web.Mvc.MvcHandler.ProcessRequest(HttpContext httpContext) +54   System.Web.Mvc.MvcHandler.System.Web.IHttpHandler.ProcessRequest(HttpContext httpContext) +7   System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +181   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
Version Information: Microsoft .NET Framework Version:2.0.50727.4016; ASP.NET Version:2.0.50727.4016
