您的位置:控制工程论坛网论坛 » 产品供求 » 供应导电滑环,帽型滑环,过孔滑环,集电环,电刷,R系列榣杆,操纵杆
杭州全盛电气
杭州全盛电气   |   当前状态:离线
总积分:58  2025年可用积分:0
最后登录时间: 2007-01-25
杭州全盛电气  发表于 2006/10/27 9:56:32      854 查看 0 回复  [上一主题]  [下一主题]
SRH3899系列导电滑环
过孔直径38mm
  • 采用先进的纤刷技术设计及制造
  • 完全满足360度无限制旋转的动力及控制信号传输
  • 标准化产品规格
  • 超长的使用寿命和免维护运转
  • 各项技术指标达到国外同类产品
  • 能为客户量身定制所需要的产品
特点:滑环特别适合应用在需要无限制的,连续或断续旋转,同时又需要从固定位置到旋转位置传送功率或数据的场所,导电滑环又称集电环、或称旋转关节、旋转电气接口、滑环、集流环、回流环、线圈、换向器、转接器。滑环能够通过简化操作和降低连接部的损耗从而改善系统。
   SRH3899使用独特的纤刷技术比传统的导电滑环有几个优势,每个刷束包含多个接触点,低接触压力,低噪音和低接触磨损速率。同时纤刷不需求润滑油,产品没有磨损遗留物。
典型应用:
  • 工业机器 -加工中心, 旋转工作台
  • 重型设备塔台或电缆卷盘,试验设备
  • 包装设备,堆垛机,磁性离合器,工艺控制设备
  • 旋转传感器,紧急照明设备,机器人
  • 展览/显示设备、医疗设备
详细参数资料请登陆公司网站:www.hzqs.com
SRH3899,
the slip ring can be used in any electro-mechanical system that requires unrestrained,continuous rotation while transmitting power and /or data from a stationary to a rotating structure. the slip ring is also called a rotary elecrical interface ,commutator,collector,swivel or an electrical rotary joint.A slip ring can improve system performance by simplifying operations and eliminateing damage-prone wires dangling from movable joints.
A slip ring are metal rings that provide a continuous electrical connection through brushes on stationary contacts.
It’s configuration is column type,each ring lies along the drum axis,like threads on a bolt.
The SRH3899 uses sheaf brush technology which offers several adventages over conventional slip ring contacts, includeing multiple multiple points of contact per brush bundle,low contact force per brush,low noise and low contact wear rates. In addition,sheaf brushes do not require lubrication and produce virtually no wear debris.
we can supply much kind of the slip ring. such as SRC,SRH,SRT,SRB.if you want to know more about our product ,please load :www.hzqs.com.   and also can produce according to your requirement.
