您的位置:控制工程论坛网论坛 » 产品供求 » 台湾TWOWAY压力继电器、TWOWAY压力开关、TWOWAY充液阀、宏盛国际
hs889
hs889   |   当前状态:离线
总积分:126  2025年可用积分:0
最后登录时间: 2010-11-26
hs889  发表于 2010/11/25 19:19:19      601 查看 0 回复  [上一主题]  [下一主题]
台肯精密股份有限公司創立於1978年,為台灣第一家專業壓力開關及預充閥製造商,本公司以 TWOWAY 品牌行銷海內外。 堅持品質,創新研發,滿足顧客的需求,一直是本公司的經營理念,本公司多項產品皆已獲得專利,並對既有的產品不斷的改良,每一個產品在生產過程中的各階段,都歷經製程管制,而出廠前的測試與檢驗,更是俱細靡遺,直到品質達到最高標準才出廠。
台湾TWOWAY压力继电器/TWOWAY压力开关/宏盛国际
DNL-050K-21B,DNL-100K-21B,DNL-200K-21B,
DNL-280K-21B,DNL-400K-21B
DNP-02K-21B,DNP-08K-21B,DNP-20K-21B
DNP-02K-06I,DNP-08K-06I,DNP-20K-06I
DNB-040K-22B,DNB-070K-22B,DNB-150K-22B,DNB-250K-22B,DNB-040K-06I,DNB-070K-06I,DNB-150K-06I,DNB-250K-06I
DNA-030K-22B,DNA-040K-22B,DNA-070K-22B,DNA-100K-22B,DNA-150K-22B,DNA-250K-22B,DNA-360K-22B
DNA-030K-06I,DNA-040K-06I,DNA-070K-06I,DNA-100K-06I,DNA-150K-06I,DNA-250K-06I,DNA-360K-06I
DNC-040K-22B,DNC-070K-22B,DNC-100K-22B,DNC-150K-22B,DNC-250K-22B,DNC-360K-22B
DNC-040K-06I,DNC-070K-06I,DNC-100K-06I,DNC-150K-06I,DNC-250K-06I,DNC-360K-06I
DNF-040K-22B,DNF-070K-22B,DNF-100K-22B,DNF-150K-22B,DNF-250K-22B,DNF-360K-22B
DNF-040K-06I,DNF-070K-06I,DNF-100K-06I,DNF-150K-06I,DNF-250K-06I,DNF-360K-06I
PSA-050K-21B,PSA-100K-21B,PSA-280K-21B,PSA-400K-21B,PSA-050K-06i,PSA-100K-06i,PSA-280K-06i,PSA-400K-06i
PSB-040K-21B,PSB-070K-21B,PSB-150K-21B,PSB-250K-21B
PSL-050K-21B,PSL-100K-21B,PSL-200K-21B,
PSL-280K-21B,PSL-400K-21B
PYC-210K-21B
DNB-2P40K-PB,DNB-2P70K-PB,DNB-2P150K-PB,
DNB-2P250K-PB,
DNB-2W40K-Pi,DNB-2W70K-Pi,DNB-2W150K-Pi,
DNB-2W250K-Pi
DNM-2P-040K-PB,DNM-2P-100K-PB,DNM-2P-250K-PB
DNM-2W-040K-PB,DNM-2W-100K-PB,DNM-2W-250K-PB
DNM-2W-040K-21B,DNM-2W-100K-21B,DNM-2W-250K-21B
TWOWAY碟式充液阀/TWOWAY/宏盛国际
SVF-32,SVF-50,SVF-63,SVF-80,SVF-100, SVF-125,SVF-160, SVF-200
SCF-32,SCF-50,SCF-63,SCF-80,SCF-100,SCF-125
宏盛国际发展有限公司
TEL:0512-55177726   55177728
FAX:0512-55177725
http://www.hs889.com
E-mail:hs-889@163.com
原产地︰台湾
产品描述
型号:PSA-280K-21B
无接点NPN集极开放,电晶体输出式油电压力开关!本体为铝合金6061,连接牙口RC1/4"
本产品特点:
.专利201496
.特殊无接点感应开关输出
.可与PRC或电脑程式读出
.可在高次数输出
.寿命可达8千万至9千万次
型号:PSB-250K-21B
本产品为新型无接点式,本体材质为6061.
连接螺牙为RC1/4".
专利:201496
负载:24VDC<100mA
寿命:8千万次.
型号:PSL-400K-21B
本产品为新型无接点式油电压力开关,连接牙口为RC1/4".本体材质为铝合金6061.本产品特点:
.专利201496
.特殊无接点感应开关输出
.可与PRC或电脑程式读出
.寿命可达8-9千万次
.输出时LED批示灯识别
型号:DNA-280K-25B
本系列为机械式油电压力开关,为压力直读式!安装为管式内牙RC1/4"
适用于油压系统压力控制信号输出!
负载:5A-125,250VAC
寿命:10万次
型号:DNB-280K-22B
本品为台湾台肯公司专业生产;最高设定压力为250公斤;压力设定为六角调动;连接为内牙PT1/4".
负载:5A-125,250VAC
寿命:10万次
型号:DNL-400K-21B
本产品为机械式油电压力开关,压力直读式,微动开关接点高容量型!安装方式为板式贴壁式!
负载:10A-125,250,480VAC
寿命:20万次
型号:DNMB-02P-250K-21B
本产品为机械式油电压力开关,安装方式为叠加加式.
负载:5A-125,250VAC
寿命:10万次
型号:DNM-02P-250K-21B
本产品为机械式油电压力开关,压力直读式,安装方式为叠加式.
负载:5A-125,250VAC
寿命:10万次
型号:DNF-360K-22B
本产品为机械油电压力开关,压力直读式!
面板式安装,油口连接为内牙RC1/4".
负载:5A-125,250VAC
寿命:10万
型号:DNC-360K-22B
本产品为机械式油电压力开关,压力直读式!
安装方式:螺牙式M22*P1.5直入油路集成块,减少系统泄漏机会!
负载:5A-125,250VAC
寿命:10万次
型号:PYC-210K-21B
本产品本体为铝合金6061材质.适用于要求上下点压差小补压之机械.
负载:15A-125,250,480VAC
    0.5,0.25-125,250VDC
寿命:20万次
型号:DNP-20K-21B
本产品本体为铝合金6061材质!
为低压隔膜式压力开关,试用于油、水、气压力源检测!具有一定的抗腐性.
TWOWAY碟式充液阀/TWOWAY
TWOWAY碟式充液阀/TWOWAY
日本岛津
日本岛津(SHIMADZU)GPY齿轮泵/GPY齿轮泵
美国MEAD电磁阀/手动阀机械阀/MEAD
日本(NIHON SPEED)KIP齿轮泵/K1P/齿轮泵
宏盛国际发展有限公司为TWOWAY 压力继电器及TWOWAY充液阀-总代理.
备注:TWOWAY 压力继电器及TWOWAY充液阀标准型号我公司都备有库存
欢迎来电咨询…
FAX:0512-55177725
台湾TWOWAY碟式充液阀/TWOWAY
型号︰SVF/SCF
品牌︰TWOWAY
原产地︰台湾
产品描述
选购指南HOW TO ORDER
SVF 100 配管法兰 Pipe Flanges
系列编号 SERIES NUMBER SVF:钢质本体 STELL BODY. SCF:展性铸铁本体 DUCTILE IRON BODY. 称呼口径 VALVE SIZE 参照性能表 REFER TO SPECIFICATION FGP 100 2 M22/5B
系列编号 SERIES NUMBER FGP:高压侧法兰 HIGH PRESSURE SIDE FLANGE. FGT:低压侧法兰 LOW PRESSURE SIDE FLANGE. 预充阀口径 PRE-FILL VALVE SIZE. 参照性能表 REFER TO SPECIFICATION 压力等级 PRESSURE RANGE. 2: 250 kg/cm2 4: 400 kg/cm2 螺丝/配管 直径称呼 NORMAL BOLT / NORMAL PIPE DIAMETER
  性能表SPECIFICATION
型式 MODEL 最大流量 MAX. FLOW (l/min) 最高使用压力 MAX. PRESSURE (kgf/cm2) 导压比 PILOT RATIO Pcontrol /Pcyl. 适用管径 PIPE SIZE 重量 WEIGHT (kg)
SVF-32 160 400 3.6 2B 1.3
SVF-50 400 3.8 3B 2.9
SVF-63 630 4.2 3.5/4B 4.5
SVF-80 1000 4.3 4B 6.2
SVF-100 1600 5B 12.3
SVF-125 2500 8B 23.0
SVF-160 4000 250 4.2 10B 50.0
SVF-200 7000 4.1 12B 85.0
SCF-32 160 3.6 2B 1.3
SCF-50 400 3.8 3B 2.9
SCF-63 630 4.2 3.5B/4B 4.5
SCF-80 1000 4.3 4B 6.2
SCF-100 1600 5B 12.3
SCF-125 2500 8B
TWOWAY碟式充液阀/TWOWAY
宏盛国际发展有限公司为TWOWAY压力继电器及TWOWAY充液阀-总代理.
备注:TWOWAY 压力继电器及TWOWAY充液阀标准型号我公司都备有库存.
FAX:0512-55177725
E-MAIL:hs-889@163.com
德国DS-117/112/502//507/802压力开关
台湾TONFOU(通福)油压配件/TONFOU/宏盛国际
美国DESCHNER KINECHEK白马稳速器
FUJI SEIKI缓冲器/日本不二精器缓冲器
